I worked Hugo HB9AFH/P on HB/SG-038 this afternoon.
When wanted to update my chaser databse with this contact I got a message: "This summit not valid at the date you entered (05/08/07).
Have I done something wrong?
Peter
Peter
In reply to ON3WAB:
Hello Peter,
in the HB- summit-list you can read HB/SG-038 “Hochalp” was valid till April 1st, 2007. So you did nothing wrong and Hugo didn’t check the summit before I believe.
73’s, Ralf
DH3IAJ
In reply to DH3IAJ:
I also worked Hugo. Does this summit no longer count for sota?
Mike GW0DSP
In reply to GW0DSP:
It seems as if it doesn’t count anymore, Mike. Don’t know why.
Ralf DH3IAJ
Bummer ahh never mind
Tnx Ralf
Peter
In reply to ON3WAB:
Bummer
ahh never mind
Tnx Ralf
Peter
Well, I wouldn’t have put it quite like that Peter, hi.
It was a pleasant QSO with Hugo anyway.
No, second thoughts you are right! Bummer:-)
Mike
With this frustration among the chasing fraternity, I can barely imagine the turmoil experienced by the poor activator that actually climbed the mountain!
In reply to M1EYP:
aparently Hugo was not aware that HB/SG-038 (Hochalp) has been moved to HB/AI-008. (this summit is in AI-canton not in SG…)
73 kurt HB9AFI
In reply to HB9AFI:
to HB/AI-008. (
Don’t you mean HB/AR-008 ?
In reply to M1MAJ:
yes i meant AR-008 , sorry…
In reply to HB9AFI:
Very confusing stuff, hi.
So, do those of us who worked Hugo claim the points for HB/AR-008, or is it still a case of no contact?
Mike
In reply to HB9AFI:
Hugo
It was a real pleasure to have a QSO with you again after such a long time. I am sure that you enjoyed the expedition and I hope that you had a good day.
Forget about the 4 points. Chasers can live without them. There will be other days and I look forward to hearing you on the air again. Many thanks for the activation.
BCNU 73
Roy G4SSH
PS
King of the Mountains Klaus once activated a whole range of mountains then discovered they did not qualify until the following month!! No problem. We all worked him again later.
In reply to G4SSH:
Very well said Roy.
The 4 points don’t matter at all and just to clarify, no one was complaining, just not sure of the situation.
Thanks for the QSO Hugo and I look forward to the next time.
vy 73 Mike
Just as Mike said Hugo, we are not angry at all , I just didn’t understand the situation. This is the first time it happened to me.
Furthermore it is you that made the effort to climb that mountain and activate, so who are we to judge?
Always very happy to contact you from any summit or just regular QSO.
Servus Hugo !!!
Peter
In reply to GW0DSP:
I didn’t work him so I’m neutral. I’d say chasers are justified in claiming it (and he can claim the activation). It sounds like he was on a valid summit and identified it unambiguously. I’m sure there have been other cases in which genuine errors in summit references have been corrected after the fact.
Only my opinion of course.
You are correct Martyn. There are past cases of an activator coming on the old Yahoo reflector after the weekend and correcting an incorrectly announced SOTA reference.
Hugo activated the same mountain as intended, and within all the rules, so he must be able to claim the activation. And if the activation is valid, then so are all the contacts with it. I have certainly claimed my S2S CW chaser points in this instance.
In cases of possible ambiguity, one can refer to a theme in the General Rules which refers to “in the spirit of the Programme”. This activation, and all contacts with it, are quite clearly in the correct spirit of SOTA, so NP AFAIAC.
In reply to M1EYP:
Thanks for the update/clarification Tom.
I will now log it, but I will gladly remove it at a later date if told otherwise.
Mike
apparently Hugo was not aware that HB/SG-038 (Hochalp) has been moved
I have seen some big earth movers in my time but this one must have been enormous.
8oD
Steve
