Hasty Activation
2-1/2 minute video of Frank/K0JQZ and I on Knights Peak. Still experimenting with GoPro Hero3(Black) to refine the time lapse interval for fast motion to fit the situation. More work needed but it’s getting better!
Cheers, Steve/wGOAT
In reply to WG0AT:
great movie Steve good way to fit more into a short time frame.
just a question you may get time to answer.
The end fed wire I notice you run it out after winding it a couple time around the squid pole and set radio up that end. I run my wire up to the squid pole as a sloper and set up at the other end of the wire. Do you think it makes any difference to performance which way that is done, and I will try your way next time I go out. Thanks…
de Ian vk5cz …
