GW/SW G/WB G/MW areas active next week on 2m FM
Next wednesday I am catching the 9.10am train from Malton down to Malvern to meet Geoff M6PYG I arrive at 1.45pm.
Weather permitting we will then head into the South Wales Region on Wednesday PM to bag two easy summits before dark.
On Thursday and Friday we will concentrate on the Welsh Borders and Mid Wales Regions. I have posted alerts for 11 summits on what is a tight schedule.
If you are in range on 2m FM please listen out for us. We will be running 35 watts on 2m FM with a vertical dipole about 3m above the ground and hope to qualify all the summits visited.
73 Phil G4OBK
In reply to G4OBK:
If I am about Phil, I certainly will listen out for you!! It will be nice to see some more of the much neglected Mid Wales being activated!!
Matt G8XYJ (TWCG - kettle can be on if needs be - Ludlow)
In reply to G4OBK:
Hi Phil,
Down in south Wales on business Mon/Wed next week. Hope to activate some GW summits Thurs/Friday before heading up to QRP Rally Saturday Rishworth. Will be listening 2M and working HF. Will check your Alerts with possible S2S’s.
Jack (:>J
GM(W)4COX
Great stuff Matt & Jack. I will try to self spot with RRT. The ones we are doing are short walks - less than 1.5 miles to the summit in most cases, similar to the wee ones Dumfries & Galloway you are familiar with Jack but easier ground for walking hihi
73 Phil
In reply to GM4COX:
I will be at the QRP Convention on Saturday, Jack. Will look out for you there!
Walt (G3NYY)
