In the process of selecting summits and programming the SMS spot for Arenig Fach yesterday (047) was used instead of (027). Some of you may know I activated two summits that day and time was tight, hence the error.
Of course this means you get four chaser points rather then two, so the only person that looks silly is me. Please correct yr logs.
S2S’s this applies to :-
M0USV/P on G/SP-017.
AND…
GM6WRW/P with MM0YHB/P on GM/SS-267.
I was going to email people privately but this will probably be more effective.
Please leave a post to inform me of the correction, otherwise you will get an email.
Thank you to all that worked me on the Bala trip with the Homebrew Minima Trx, it gave it a real good soak test, for something that is mainly produced from 2N3904’s and an Arduino it sure does work well.
I was a bit surprised to hear you on Mwdl Eithin when you had said that you were heading for Bala, but I was chuffed as I needed it for a Complete!
Oh, well, more points as you say, and good to hear your homebrew rig on the air :o)
Thank you for the heads up, I have corrected my log
I was pleased to see you up there today Adrian, very good going indeed. I was contemplating doing them yesterday, but I thought it would prove a better test for the HB if I did more summits further apart. Plus the fact they where covered in cloud and looked very wet indeed. Where did you park for the two summits today (011- 018) ?
I am trying to learn the code, so I can work a few more of you.
I attempted 047 last weekend with Dad, but we turned back to the pub due to slow progress in the evening, I will activate it this Thursday if that is good for you ? for your complete, I shall set an alert.
In reply to G4AZS:
I parked near grid ref: SH 822393, there isn’t a car park as such, but there were two other cars there today as well as mine, just tucked in on the verge.
Keep up the good work, you will not regret it!
I am hoping to be out on the hills on Thursday, but I’m not sure which yet. I’ll watch out for your alert and try to work you from home or S2S. On the other hand, I might have to do an airport run, but fingers crossed!
