GM/CS-031: Worlds Collide, Awkwardly
One of my running club pals had suggested at the pub earlier in the week that she might fancy a run up Carn a’ Chlamain at the weekend, and I and a wee group of folk thought it’d be a good idea to tag on. It’s a nice run up Glen Tilt, and it’s a Munro I’ve never bagged before, and getting out for a much needed long run would be a perfect way to spend a Saturday.
All this is perfectly normal, it’s a way I’ve enjoyed a lot of Saturdays, but this time I had a bit of a daft idea: what if I chucked a radio in my pack and tried to activate it as GM/CS-031 while I was out with them? When I asked in the group chat if they’d mind me taking a radio along, I was largely met with expressions of confusion, but nobody seemed to have a problem, so that was sorted: I’d bring the wee FT-65 and an RH-770 in the trail pack and see how quickly I could knock out four contacts.
The big problem in my mind was that I’ve done almost all of my SOTA activations solo, and the one where I had company involved a very patient partner who was happy up to a point to get cold and bored while I tried (and failed) to eke out four contacts from the 2 metre band. Trying the same with a group of lightly-dressed trail runners without the same romantic attachment might be a bit of a harder sell.
Anyway, we got to the bottom of the trail and enjoyed a fairly gentle jog up Glen Tilt. The route essentially involved a 12km gravel road to the base of Carn a’ Chlamain itself, then a short but sharp pull to the summit, and then repeat again in more or less the opposite direction. Rather than ascend by the “normal” path suggested by Walkhighlands etc., we opted to climb by the smaller path just beyond the Forest Lodge, as used in the Full Tilt Ultra race route.
My daft plan then, was that I’d try and make a faster ascent than the group to gain a bit of time to faff about with the radio, I’d see them at the summit, and hopefully I wouldn’t have to hang about long before I could catch them up again on the way down. It’s worth noting that this plan might almost have worked, was it not for the fact that the rest of my group were all experienced ultra runners, with 70, 90, 160 and 200km races under their belts this season, including one who’d just used the Full Tilt Ultra race including this very hill as a piddly wee warm up for the monstrous Kerry Way race.
I tried my best, and boosted away to an early lead, and after a couple of minutes felt a very strong sense of regret as my heart rate reached some quite frankly unwise and unsustainable numbers. The steep wee switchbacked path seemed to go on for an eternity before the gradient eventually eased a touch as the summit finally came into view. Although conditions had been very pleasant down in Glen Tilt, the forecast strong winds had really started to materialise in a big way as I reached the final step up to the summit.
With a mind for quick deployment, I managed to throw a load of layers on my back, find a boulder to perch on and extend the RH-770 on the wee FT-65. My first QSO was a nice easy one down the A9 to Killiecrankie. I’d just managed to overhear Archie @GM4KNU out on GM/SS-236 Corse Hill as the rest of the runners made it up to the summit - so much for getting ahead of the game! The strong winds meant they weren’t very keen to hang about, and as soon as they had done the obligatory patting of the cairn they were off and the pressure was on.
I didn’t have to wait too long to catch Archie for a S2S QSO. I then managed to catch Gordon @GM4OAS over in Morar, and rounded off my day with a second S2S with Ayden @MM6DQG on GM/ES-032. This wasn’t a day for hanging about, and although I only had time for the bare minimum four contacts, I was happy that two of them were S2S and I’d covered a good range of the country.
The tricky part now was that by my estimation, my pals had about a 12-13 minute lead on me. With only about 15km back to the car park, I’d need to be making about a full minute per kilometre faster than them to try and catch them by the bottom of the road. Again, this would likely have been a whole lot simpler if my pals weren’t all seasoned trail runners!
I descended off the hill by the “simpler” route, the double track leading back down to the glen floor at Clachghlas. Even with good forward visibility down the track, my pals were nowhere to be seen. As the double track switched direction back towards Clachghlas, I took a wee shortcut path off the end of the ridge to Slochd Dail Mhoraisd, convinced my pals would’ve likely done the same thing. I got my head down and started bashing out the kilometres back towards the car park at about as hard a rate as my legs could carry me, not wanting to leave my mates sitting in the car park wondering when I’d appear behind them.
Just as I was approaching the car park, I saw a message from one of the other runners: “we were waiting for you at the bottom” it read. I was relieved, in my mind they’d only reached the car park about 5 minutes before me. However, it was only when I read the message fully that I realised what they had in fact done was not take my shortcut and had waited at the bottom of the hill at Clachghlas, not the bottom of Glen Tilt. Thankfully, once we had enough signal to work with, we realised the muppetry and I waited in the car park for them to make their way down to me.
Although the only member of the party with the car keys was still a good distance up the track, I found a comfy yellow grit bin to sit on, threw on all the warm layers, and thankfully had enough phone signal to upload my short activation logs to SOTAdata while I waited.
Moral of the story: I’ll probably not bother combining running with pals and doing SOTA again! I think I’ll keep mountain radio to working on my own schedule and save dragging other folk along, giving myself plenty of time to faff with masts and suchlike.
The silly thing was, I’d considered chucking a pair of wee PMR446 walkies in my bag so that I could give something to my pals to try and avoid something like this happening. Whether or not PMR446 would’ve worked down in Glen Tilt might’ve been a different story though…
Activation log: Sotadata3
Strava route: Strava Flyover 3D replay
Can confirm. Tis monstrous. They must be absolutely bonkers! :sweat_smile: Source: I ran it (the Sneem to Killarney via Kenmare Kerry Way Ultra and the Waterville 130km races).
Could see that happening before finishing reading the word ‘daft’ :grinning_face_with_smiling_eyes::rofl:
That is a really solid idea. Not just from a safety perspective but would give them some sort of interaction too and what if one of them got a bit curious about amateur radio? Might have inadvertently on-boarded new jamons!
A hero’s choice. :face_blowing_a_kiss::ok_hand:
Good work sir. I’ve only done a training run with an activaton a couple of times. A faff indeed so felt every word of your report. Nicely done, my Easter bonnet is doffed in your general direction! :blush:
Surely they all pack additional layers should they trip and break a leg.
Glad you managed to qualify the summit, going with other non-hams does tend to lead to rushed activations and a constant sense of guilt!
I really enjoyed reading the report Ross, though the scenario was totally alien to me. I’ve never been able to run any distance, being made more for endurance rather than speed and even that ability has been challenged in recent year due to aging and health issues.
I am pleased it all worked out okay in the end and you haven’t been ex-communicated by your running friends. In my experience SOTA doesn’t fit well with other activities, even casual hikes… someone is bound to find all the hanging about not to their liking.
I used to run but prepatellar bursitis (one knee actually got infected) and a runner physiotherapist made me stop. I thankfully haven’t had issues since.
I recall a few activations while blowing out my rear getting to the summit, fell runners gliding by me like leaves in the wind!! :rofl:
Great report Ross. (I only managed Archie yesterday from home QTH).
Aye, sounded like a pretty mad undertaking, but also sounded like a really lovely event with good organisers.
I think when I tried explaining how ham radio worked in the car they were just a wee bit confused and bewildered more than anything else! Still, PMR radios are just one of the many brilliant things you can get for very little money from Decathlon (and they’re tiny too, so I had no excuse).
I’ve not found activating and running to be a huge issue - the biggest trouble is staying warm, then your legs invariably seizing and cramping while you’re sat on an unforgivingly-angled boulder.
Yeah, everyone’s usually got layers on board, but it often tends to rely on stuff like space blankets and body bags that nobody wants to unfold just so that their muppet pal can faff with a radio for ten more minutes. Saying that, doing ham radio on summits has definitely got me to re-evaluate what I’d take in my emergency kit, as it’s hard to estimate just how cold you really can get sitting still without getting some real life practice!
Yup, I think that’s the big lesson learned, solo efforts only from now on!
We’ll see… the group chat has been eerily quiet this morning :joy:
As a small technicality, we’re trail runners and not fell runners, those mad wee whippety looking fell runner guys are a source of amazement to us too - out in the worst possible conditions with nothing but a club vest and a bumbag containing a small animal they’ve caught and slaughtered by hand in case they get peckish.
Cheers Doug, I’ve not had a lot of joy Glasgow way from these hills. Last time on the nearby Beinn Dearg GM/CS-023 it was all Edinburgh, couldn’t even get Peter @GM0VEK in Kirky!
Sure we haven’t met? :joy: I’ve got legs like a baby giraffe and can be found off path eating leaves. :face_savoring_food:
The ones I saw up Morven during a January blizzard didn’t. Shorts and vest tops, with one bum bag between the four of them.
If they had an issue, they would have been relying on help from any passing hill walkers for survival.
Blimey. Madness!
Running in those conditions you’d be wanting a running pack with mandatory kit (same as the mandatory gear checklist for races).
Depending on terrain, course length yadda yadda you’d want waterproofs, first aid kit, foil blanket, compass and so on. Kit is inspected before a race start too. No kit or a missing item, no race.
For a training run I’d apply the same strategy. One it is just common sense. Two it’s good practice for race simulations. Vary the pack based on what it is you are doing and the conditions.
One bumbag between 4 sounds like they were squirrelling gels and perhaps a first aid kit. Poor form, particularly if their run had involved calling out for rescue or reliance on passers by just because they wanted to pack light.
Rule #1 of trail running. Don’t try and be Billy Big Balls/Belinda Big Bosom. Safety first. Every time.
I’ve definitely seen some daft stuff from the hill/fell runners over the years. I know certainly with a lot of folk there’s the sense that if you get away with it enough times, you don’t really need all the safety backup stuff… which works fine right up to the point that you stop getting away with it.
Aye, that’s very much the approach I’d take. If you’re going to be racing with it, you might as well train with it too.
For me, the bare minimum is waterproof jacket and trousers, a warm mid layer top, warm hat and at least one pair of gloves. I’ll usually carry a foil blanket and body bag, a toilet kit (ziploc bag with toilet roll, lightweight trowel), and a wee mini first aid kit. If I’m going higher in the hills or out in the winter, I’ll also pack a synthetic insulated jacket.
Aye, it’s very tempting to try and save weight where you can, but you also want to keep coming home more-or-less alive!
It struck me that a broken ankle would result in any passing walkers putting themselves at risk. Spare clothes and a bivi bag would be needed. Lots of spare clothes, because their legs would also need covered.
Then there’s the 4+ hour wait for the MRT. That wouldn’t be pleasant for the injured or their helpers. No helicopters in that weather. They thought they were cool, but it’s probably one of the stupidest things I’ve ever seen on a mountain.
Anyway, that aside, well done on a fab day out and you need to take your radio every time. When I did the South Glen Shiel Ridge with my ex-work pals, they told me I had to take it, as I would unlikely be back. :blush:
I hope I never end up in a rescue situation, but if I ever do, I secretly hope that there, in the depths of the blackest night and the gnarliest of blizzards and gales that would blow Giant Haystacks down…
A Saint Bernard appears from the blizzard, with one of those little barrels of something nice aound its neck. :heart_eyes:
I only run if I’m being pursued.
Ah I don’t know, I reckon I’d take any excuse to go and do the Shiel Ridge again, radio or otherwise!
Aye, there’s definitely plenty of competition for that so it must’ve been a special one!
I do wonder if the Skye MRT dogs carry a nice wee Talisker on board just in case? I’m sure you could get at least a wee selection of miniatures in those wee dog backpacks you could get on a typical border collie!
A wise approach!
Anyway… after all this talk of mountain safety equipment, guess who ended getting to do a real life test of their rucksack first aid kit on today’s activation? (Just walking, no running, but more or less the same first aid kit)
So what we really want isn’t a helicopter and an MRT in our hour of need, but a Saint Bernard hauling a Globe drinks cabinet, a selection of tipples and a cocktail shaker.
Oh, and a choice of those little cocktail umbrellas wouldn’t go amiss either. :grinning_face_with_smiling_eyes:
Ouch !
I could make some stab at a witty comment but I think just ‘ouch’ will do. You’re smiling so I guess nothing too serious.
We should be up in Scotland for another couple of weeks in the camper but, about a week ago, my partner, Dawn, missed the last step coming down the stairs at a mate’s place in Balmedie and broke a bone in her foot. A trip to the hospital in Huntly resulted in support boot and crutches being dispensed. She can’t drive and we’re heading slowly back south. I’ve been told I can do Penyghent on Thursday….fingers crossed for some dry weather.
