Hello everyone,
Sorry for the delayed reply. The number (and quality) of replies have kept me busy with reading, and thinking.
I should have mentioned that I am thinking about 10m because it is behaving (and the SOTA challenge), and it is a band I am willing to experiment with since the antennas are smallish. I will, of course, have antennas with me that can cover lower frequencies. Probably an end-fed half wave cut for 40m, and a linked dipole. Backup and backup.
I also should have mentioned that I will be operating SSB, I am not yet capable of CW.
MM0EFI, thank you for the report. I contacted GM4JXP and have some details on the Moxon and Delta.
G8CPZ you do have a point. Though it would be fun to be able to hit W7A, leaving it up to chance is also most certainly less disappointing than actively trying and failing.
ZL1THH the feed point conundrum with Delta loops is fascinating. Collin M0MCX did a video modelling them, and if I recall his plots were different. Or maybe his were in line with this graphic, and I had another article which was contradictory. It seems that most people do feed 1/4 wave up from a corner, but I also know people who feed them at the top.
N6IZ I should pack a vertical, though I guess I could just use a dipole like an L. I have never operated on salt water, but I am aware of its magic.
K6ARK, I had neglected the half-square when reading the ARRL antenna compendia. Interesting design for sure. I may look at turning the endfed into a linked endfed to make this a possibility. Though, I am not wild about taking two masts.
SP9TKW this is a good pragmatic idea, but I am not usually this organised. Maybe I should be. I shall make sure I have good 20m options, and add 15m to the linked dipole.
G8CPZ I have not looked too much at the topology. From what I can see, it looks like the islands are going to be similar to Iceland, quite old fjord-like mounds 500-800m in altitude. And some violent crags like the northern coast of Scotland. Landscapes I know well, but will probably find chilly since I have been softening in the desert. I have very little experience with verticals in the field.
For now I shall continue reading, and continue to improve the antennas I already have.
Thanks,
Tobias KK7BCO/2M0TFF
