G4YSS:G/NP-026 Kisdon on HF, 21-10-25
G4YSS: G/NP-026 Kisdon on HF, 21-10-25
Issue-3 incorrect callsigns - pse rprt further errors (thanks!)
Activation of KISDON G/NP-026 - 1 point
Tuesday 21st October 2025 (My 1st activation of this summit)
Bands: 40m, 15m & 20m CW & SSB QRO (2m-FM QRP - no QSO’s)
All times: BST (UTC plus 1hr, UOS as ‘z’)**
EQUIPMENT:
MX-P50M, 50 Watt HF Linear Amplifier
Link dipole for 40m & 20m (30m & 15m) on a 5m H/B CFC mast
HRB 11.1V/ 5 Ah Li-Po (No9) battery (fully discharged)
UV-5R H/H. 2-Band, 5W-FM (with filter) & J-Pole for 2m FM
UV-3R H/H. 2-Band, 2W-FM in top pocket
Garmin GEKO-301 GPS
Pack weight:10kg (22 pounds) inc Primaloft jacket
INTRODUCTION:
After a SOTA lifetime of largely ignoring one-pointers, I find that lately they have become attractive. I knew the day would come eventually and NP26 has been pencilled in for a while to provide a try-out for my partly recommissioned Achilles tendon after the mishap on SP1 in April.
Our base this time was the Kearton Guest House in Thwaite, Swaledale. This is run by Caz and Adam since they acquired it a year ago. Although I am new to it, my XYL isn’t, having stayed there for two or three family holidays between 1966 and 1968. Yes, that’s a while ago!
B&B for the two of us for 7 nights was £880 and we had our evening meals there too, adding typically £24 per person for two courses. This is a dog friendly establishment - luckily I still had a bag of Finn’s treats in my coat pocket. Most people are passing through, staying just one or two nights and it’s bang on the Pennine Way. By the start of November, in Adam’s words, trade falls off a cliff. There is an attached tea room which opens Wednesday to Sunday and a bar.
At 196m of ascent and 4.8km round trip, NP26 looked suitable for my ‘re-training’ with possibly one caveat. The first ½ km or so is steeper than I would have preferred so my XYL suggested the use of sticks. Sticks!. ‘Oh OK then, if I really must.’ She bought me some months ago. In fact because the forecast was poor, I ended up with a stick in one hand and a furled umbrella in the other. To be honest they did help but they can be a pain of you want to take a photo or fiddle with the GPS etc.
EXECUTION and ROUTE:
Note: The grid letters change from NY to SD part way along this route:
Though there’s a path starting from the Kearton in Thwaite, possibly the easiest way up this one is to drive 1.7 miles north up the road towards Keld. There is space for two or three cars in a pull-off at NY 8922 0062 and the advantage a 317m ASL start point.
Cross the road and walk down the track signposted ‘Muker 2.5 miles’ which curves down to a ford. If the beck is deep take the raised pavement to the right. At NY 8922 0058 the track swings left and goes steeply up to NY 8927 0060 changing direction right (SE) to NY 8935 0052 where a path crosses.
Shortly after this the gradient eases a little. Continue up a grassy track to NY 8940 0010. At some point the ways fork but another wooden Muker sign clarifies that you fork left through a gate. Carry on up past SD 8952 9947 to SD 8972 9923 where you take a sharp left to follow the boggy quad track along the east side of the wall going NNE.
Never very good and somewhat boggy, the quad track becomes less well defined before you arrive at the place where the walls fork (NW & NE) at SD 8982 9965. Continue to follow the wall going NE, aiming for the 499m summit which is at map ref SD 89902 99848.
I use the word ‘aiming’ here because unless you’re willing to climb a 6-foot wall to get there, you’ll have to be satisfied with falling short by around 60m. I walked as far as SD 89901 99780 which is 64m from the top. You could get a little closer but the wall turns west after a short distance, taking you further away. As a teenager, I may have been tempted to climb the wall but not nowadays.
As for operating, this wall provides an excellent wind break but not today or at least not at this point today. There was quite a stiff breeze coming from the WSW so I backed off to where the wall runs N-S at SD 89878 99731. Here someone has arranged some stones to make a small seat a few inches off the ground. It’s perfect for activating and well within the AZ. Be careful though. Just along from here, the wall is doing a side slide and threatening to collapse.
I set off walking at 10:28 using one stick and the umbrella to tackle the steep part. However it wasn’t long when I was attacked in the side of the head by driving drizzle after which it was just the stick. The chain on one of the gates is a bit short and one further up has broken.
A farmer appeared on the track having driven his quad up the steep side of the hill. He opened the gate 30m ahead of me, drove through and then stopped as if he was going to close it. Not so, it was only so that the sheep dog could jump on the back and off they sped. I was in a quandary as to whether to close it or leave it open. A real conflict. Close it and annoy him because he was intending to drive some sheep through it or obey the country code. I left it open thinking he’d reappear but I never saw him again and nor did I see any sheep.
KISDON G/NP-026, 499m, 1pt. 11:19 to 16:27. 10C, 20mph wind, overcast with occasional drizzle and sunshine for about 30 seconds. WAB: SD89, LOC: IO84WJ (no trig). Intermittent phone coverage (EE) was absent much of the time. Just sufficient for spotting but not always.
Setting Up:
There is grass next to the wall but deep heather further out. In my recovering state I was being careful where I put my feet and what angle the left one was making with the ground so I was a bit slower than formerly. The dipole on its 5m mast, was rigged parallel with the wall with the end strings wedged in the top of it. With the sit mat/ map case on the handy stone seat I was well set for the afternoon.
7.032 CW - 15 QSO’s:
This started very slowly at 11:00z and it took nearly half an hour to raise the first eight. After trying earlier I only managed to spot myself by 11:18z and for that I needed SMS. After much CQ’ing: EI6DN John in Co Neath replied followed by IN3NJB Roberto - Sarche. Next HB9DIZ Markus – Lucerne; G4ISJ/P Peter – apparently a POTA station; DB4REB Ralf – Xanten; and G4OIG Gerald in Northampton, sending his Morse on a ‘proper’ hand key.
Next: PD1RO Rolf – Koningsbosch; G4WTF Ian – Hereford City; DL1FU Frid – Biedenkopf; G4OOE Nick in my home town of Scarborough; DL2ASG Martin – St. Gangloff; PG4I Joop – Culemborg; HB9CLT Tom in Romanshorn; G4FKA Geoff – Coalpit Heath and G0HRT Rob at Milton Keynes.
Apart from one 579 all were 599 to me. Coming back were six of the same with the rest ranging down to 329 which came from Tom in HB9. Power was 30W.
7.160 SSB - 20 QSO’s:
There was no one on the WAB frequency at the time but there’s almost always someone monitoring. All it took was, ‘Is this frequency in use?’ and Dave G6LKB (Ulverston) came right back. I had to disappoint him – NP26 doesn’t have a trig point. Furthermore even if it had, I couldn’t have accessed it anyway. Peter (Peterhead) MM3PDM overheard the conversation, informing me that the trig point rules had changed. Instead of a 30m radius circle, your station was now allowed to be anywhere inside a 100m one.
This is a change that was needed. Beside the A171 at Cloughton near Scarborough a trig point stands in the middle of a farmer’s field, more that 30m from any road but less than 100. More importantly, when SOTA activating in the depths of winter, I have had to forgo the protection of a wall or other windbreak to set up out in the open and slowly freeze just to be near enough to the trig (eg NP31). This change gets my wholehearted approval!
Continuing on: G0FEX Ken in Leicester (‘Say Hi to Phil G0UUU for me’); M1AOB Richard – North Devon (ST30); G4RQU David in Hunstanton (FT950/ G5RV); 2E0FEH Karl in Saltash, Cornwall; PD1CW Patrick – Hulst; M7GNR Barry – Silloth (NZ44); G4FKA Geoff 8mls NE of Bristol; G0MHF John at Birkenhead.
Waiting patiently was Paul G4IPB collecting the SOTA from Middleton-in-Teesdale. Paul is one of the ‘Top Band Gang’ but I wouldn’t like to say when the next 160m offering will occur? Well not from me at least but it was fun while it lasted. Rolling on: M8PCL Garry at Bridlington (TA16); M0WPS Wayne – Brum; DG3GAI Klaus in Unterkirnach; G8VNW Nick in Threshfield – another keen 160m chaser and M0NOM Mark in Windermere who I’d worked the day before from the car (thanks for Claife Heights LD53 Mark).
Frantically turning the log page over and fighting with the clip, the next entry was G7SXR at Driglington near Leeds. Mark sounded strangely ‘SSB’ish’ after our many FM QSO’s both SOTA and local. Mark listened for out and also tried calling me later on 2FM but to no avail. NP26 is well screened.
The final three on 40m-SSB: M0SGJ Steve near the lighthouse in Withernsea in TA32; G6AEK Dave at Blackpool and to round off the session – MW9WJS John in Newport.
Power was 30W again. Reports were mainly 57 to 59 but I also got a 54, a 55 and a 32 coming from Klaus. As the skip was running at the time, I knew he’d struggle so I gave him priority. Several times I stopped to ask if there were any mobile stations wanting to call in as I didn’t want to block the normal running of WAB for the sake of SOTA and me waffling too much. As it happened, there were none.
21.061 CW - 6 QSO’s:
Activating 15m next eliminated the need to get up and change links, although I was having to stand up most times to get the phone to work. VSWR for the 40m dipole on 15m is around 2:1 but it works fine.
After another self spot I barely had to call CQ. In the 15m log: OH8TX Jorma – Jarvenpaa (599/ 579); AC1Z Robert in Alton, New Hampshire (first DX of the day - 599/ 559); HA5MA Laszlo – Budapest 599/ 569); WF4I in West End, North Carolina (599/ 539); ND0C Randy running 5W QRP from Worthington, Minnesota (579/ 326) and LZ4GL George in Byala (579 both ways). Power was 50W but this was eating the battery for which I would pay later.
21.320 SSB - 7 QSO’s:
Signals on 15m were better than average so when CW dried up, my thoughts turned to SSB. Another self spot and maintaining the 50 Watts brought in: EA1FQO Jonatan – Vigo; EA7ANC Antonio in Granada; OK7WA Frantisek – Halenkovice running 100W to a vertical; 3Z9VI Tom in Wadowice and SP9GKS Tomek – Myslowice.
The next caller was F5MDY Nic in Deyme. I praised Nic for his good audio. He came back in amazement, ‘I’ve got Covid!’ (Don’t knock it; it’s a lot cheaper than a speech processor)! Get well soon Nic. A familiar callsign, usually using CW, finished this off – OH3GZ Jukka in Toivakka.
14.065/ 14.062 CW - 16 QSO’s:
I looked at 14.061 but there were clicking noises there. Tuning down, I found wall-to-wall woodpecker - very loud. To clear this completely I had to pick 14.065, self spotting there. Bad idea or is it just that my current knowledge of the bandplan is lacking? Before being convincingly wiped-out I logged five stations with 30 Watts: DL6MST Klaus – Wernigerode; DL1HBT Tom – Hamburg; DL8DXL Fred in Laussnitz; DL4SO German in Bad Waldsee and EA1AER Juan in Leon.
Nine reports were 599, one was 579 so propagation was good; then came a deafening data signal while I was wrestling with a part callsign OK1U?J who never stood a chance. Through the racket I sent QRM-QRX but it didn’t stop. 14.062 was clear so as well as sending the QSY QRG through the data, I was lucky enough to get a spot away.
The chasers must have heard one thing or seen the other as they were still queueing up: Now on a clear 14.062. First I called for OK1U?J but without response. I tried this twice more at intervals but it wasn’t to be. He must have gone off in disgust to chase someone a bit more competent than me. In the log: OH3GZ - Jukka prefers CW to SSB! W4JKC Tom in Anderson, South Carolina; F6FTB Christian in Pasques; SV2OXS Christos - Katerini and after opening an improvised page-3 of the log, S52AU Borut – Ljubljana.
Six more: UR7EZ Mike – Ukraine (GL); SQ7SZ (Poland); F4VVG Simon – Scheibenhard; SA4BLM Lars – Siljansnas; K4QS Charles – King George, Virginia and finally RA1QX Alex in Volagda. Towards the end of this QSO the rig abruptly cut out. The battery was almost finished and I had no spare. Switching off the linear, I finished the QSO with 5W. Apologies if you were left wondering what had happened.
14.292 SSB - 3 QSO’s (QRP):
Aware that more that 50% of QSO’s were logged in CW, I self spotted a 20m SSB frequency. Unfortunately this would have to be with the amp switched off. With the FT817ND on 5W I managed to work EA2CPG Pedro in Cantabria (59/ 57) but then the rig cut out again. I soon found that one Watt was the limit but I could only manage two more stations: OE1KEB/P Karl (home QTH Vienna) and S57ILF Franci in Jesenice. The exchange for both of these was 57/ 44. With my next port of call 500 mW, I really wasn’t winning here but thankfully no one else called. Also in deference to the battery, a 5Ah HRB Li-Po, it was time to quit.
145..500/ 145.400 FM – NIL:
I took HF down and replaced it with the J-Pole on three of the mast sections. There have been 107 VHF QSO’s from NP26 but I was to be unlucky today.
After a self spot and using my UV-5R, I called alternate CQ’s on S20 and S16 for half an hour in recently arrived drizzle. I found out the following day, when working him from NP6, that Mark G7SXR had been calling me. Either his signal didn’t get through from Leeds or I was on one frequency when he was calling the another. Thanks for trying Mark! If I ever return to this one with 2m-FM only, I’ll try to bring a more capable station.
The Descent:
The walk down, initially in wind and drizzle, took 41 minutes, arriving by 17:08.
ASCENT & DISTANCE:
Ascent 196m (643ft) / Distance 2 x 2.4km (3 miles in total)
Start point at 317m ASL then dipping to 310m to cross Skeb Skeugh beck
Walking times:
Ascent: 51 min
Descent: 41 min
Summit time: 5hrs-8 min
QSO’s:
15 on 40m-CW
20 on 40m-SSB
6 on 15m-CW
7 on 15m-SSB
16 on 20m-CW
3 on 20m-SSB
0 on 2m-FM QRP
Total: 67
COMMENTS:
The day before this had a bad forecast but in fact no rain fell and apart from chasing Mark’s SOTA (M0NOM/P on LD53) from the car at Tan Hill, Monday was wasted. Today the forecast was no better and with the limited days draining away I felt I had to go for it. It was unclear to me whether the field boundary lines on the 25k map represented fences or walls. Our host Adam told me that walls existed on the summit. You bet! When I found them they were six foot high and the wind was just right for them to work their magic. It meant that I would be able to stay for several hours in relative comfort. This is how I like it but I still took an umbrella – an item I hold in high regard especially for SOTA activations.
Adam also remarked that it is unusual to climb a UK summit without physically being able to bag the summit proper. Maybe someone knows a work-around without resorting to climbing high and in places, shaky looking dry-stone walls. The last thing we want is that they get damaged.
Having made it up there with a recovering Achilles injury I was thankful enough to get within 60m of that elusive cairn. There is a tall stone structure close by too but you can’t get over to that either. Apart for the farmer on his quad, I saw no one on the hill today and wildlife was limited to the occasional Red Grouse. Their sudden loud alarm call really makes me jump. Fools me every time.
Band conditions were really good. I gathered, during a mobile QSO with Mark G7SXR two days prior, that there’d been a minor solar flare with the MUF around 20 Mhz so I’m more than grateful for a timely recovery. 21 MHz was working very well and it’s long time since I had that many DX chaser contacts with the USA coming in stronger that usual.
I had a thoroughly good time, barely noticing the cold wind and drizzle apart from the latter on the log. It was great to be back amongst the G/NP’s again with the added bonus – a new one to me hitherto ignored but now a dear friend like many of the others. On the subject of friends; lovely to chat to old friends and new. Every op has his or her own unique story.
What next? This feels like progress. Yes, I’m slower and as a precaution I use a stick (or two) but I feel I could now move a little further down the road to recovery. Small increments is the key but even then there will need to be limits.
To ALL STATIONS worked and the SOTA spotting service. Also to 2E0FEH Karl for a spot.
73, John G4YSS/P
Photos: 921p-732p-start-201p-1-3-6-9-13-15-16-45-19-20-615p-756p-map-29-832p-33-37-38-spot-53-55
Above: G/NP-026 Kisdon from Kearton Guest House, Thwaite
Above: Parking place. Take the track at the sign ‘Muker 2.5 miles’ by the tree at top left
Above: Follow the track which hairpins left down to a ford, swinging right and reappearing at left of photo
Above: Route overview from the road. Initially hidden by trees, the walled track slopes up left to right, passing in front of the house high on the hill
Above: Cross the ford - easy today. Wash your boots on the way back!
Above: Looking back having cleared the trees
Above: Looking back again
Above: Coming up to where the ways part. Take the track through the gate ahead
Above: Sign for Keld or Muker. Take Muker
Above: Straight on
Above: This is where you leave the track. Pass through the gate and turn sharp left keeping the wall on your left
Above: Take the vague quad track beside the wall. It can be boggy (photo taken on descent)
Above: Summit coming into sight
Above: Substantial walls
Above: Another shower of drizzle
Above: This is as close as I could get without climbing. Maybe there’s a gate somewhere?
Above: Setting up HF
Above: Activation of NP26 on HF
Above: All good for a 5-hour stay
Above: VHF setup. WX deteriorating. More driving drizzle
Above: 2m-FM - Low Expectations
Above: On the way down. House with Mobile phone masts
Above: The final approach to the road. Car roof just visible
Lovely to work you John, Pleasantly surprised to work you on 20 as by the time of our QSO condx to UK now best on 21 MHz or even higher. Your detailed travelogue and photos made for fine after dinner reading tonight.
73 to you and your family,
Tom, W4JKC
Having walked via a shorter route to Kisdon summit from the same starting point as you in previous years, this year, as far as I can tell from your photos and map references, I followed pretty much the same (longer) route as you did after having read a non-SOTA walking blogger recommend it as ‘easy’. I found that ATM route boggy and overgrown and had to get my dogs and me over a stone wall to get to the summit.
Unfortunately, I deleted my original route from OS Map app but I know it leaves the southbound right-of-way 4-wheel track you were on via a gate on the left before you get opposite the short 4W road leading to that [mobile network base station] transmitter on the rise.
The path is indistinct after the gate but you are heading east up the hill looking for another gate in the boundary stonewall (I think it’s at NY 895 002) and from there make your way roughly SE to the summit.
It’s about 34-40 minutes’ walk. No bogs, no walls to clamber over.
Hi John,
Great report as always. I remember Kearton Tea Rooms very well because when me and my dad Tom @M1EYP were walking the Pennine Way back in 2006, we arrive in Thwaite on one of our Pennine Way days after descending Great Shunner Fell G/NP-006 in very horrible rain. We decided to see if Kearton Tea Rooms would allow us in even though we were very drenched in our walking clothes so that we could shelter from the rain and have a hot chocolate there as well and thankfully they were very friendly and allowed us into the tea room, we did have to wear bags over our walking boots though. By the time we were finished at Kearton Tea Rooms, the rain had cleared and we were able to enjoy our walk to Keld via the Pennine Way.
Now that you have activated Kisdon G/NP-026, Rombald’s Moor G/NP-028 and Bishop Wilton Wold G/TW-003, maybe it is now time to consider activating the remaining G/NP and G/TW one pointers John which are Dutton Pike G/NP-027 (very steep), Sharp Haw G/NP-029 (nice hill with bench on summit), Urra Moor - Round Hill G/TW-001, Cringle Moor - Drake Howe G/TW-002 (nice hill with a nice cafe at the parking spot), Gisborough Moor G/TW-003 and Normanby Top G/TW-005 (my dad recently found a nice spot within the activation zone for this one to activate from).
Jimmy M0HGY
Many thanks for another excellent report John. Five hours on a summit and no special event! Well done on getting up there and it is pleasing to note no after effects on the Achilles. I was really pleased to get you on 40m CW… is my straight key “tone” that evident? :joy:
I really enjoyed Kisdon. I don’t really know why it has such a low l;evel of interest - just 69 activations including this one. The route that Paul G4MD and myself took was more of less as per Andy’s description. The longer route does avoid the sting in the tail, but we wanted to get close to the actual summit to maximise my chances on 2m. In those days I wasn’t doing much HF.
I pulled up my report on the activation with Paul on 15th November 2010… it seems like yesterday. An extract:
We were alerted for 08:30 and were just a little early when we got on air. My first call went unanswered, but the next call brought in Geoff G6MZX, shortly followed by Bob G6ODU. I was spotted by Bob and also by David G6LKB. John MW1FGQ called in for QSO number 3 and we tried on 70cms, but nothing was copied either way on that band. Back on 2m at 08:30, the run then started. After working David G6LKB, I raised the power to 40 watts to work Laurie G6XLL and David G2BOF and left it there until the frequency went quiet at 08:45. I had 11 in the bag with Don G0RQL providing the best DX. After a few unanswered calls on 70cms and a wander around to take some photographs and get my circulation going, I put a call out to the north on the 2m SSB calling frequency and Jack GM4MOX in Kirkcaldy came straight back. So much for Kisdon being an RF black hole!
This is how you get 2m RF out of Kisdon
Paul operating from the cairn
73, Gerald G4OIG
NP26 on HF 21-10-25 - REPLIES TO COMMENTS
Tom, W4JKC
Thanks Tom,
Yes, it was a surprise for me too. Due to my band use history - (I’ve been busy doing 160m SOTA for over 20 years) - I don’t come up to 20m too often but I should. Also, as you say, 20m was a bit low down for signals that good at that time. I must say going a bit higher to the dizzy heights of 21 MHz has also made a pleasant change.
Thanks for reading the report. I don’t really know why I write them like I do but I think it’s because I can enjoy the experience twice (the second time without getting wet) as well as creating a record for myself should I need to refer to it in the future.
I hope we will QSO again. I always get a little excited when signals come in from that distance and we need to make full use of the big mirror in the sky while it’s working so well.
I think you collect WAB: SD89 Book No 7664 - plus
Thanks again,
73, John
Andy G8CPZ
Thank you very much for that tip Andy. From your description, I can now roughly surmise your route on the map and I would have been keen to go that way had I known. However that was before April this year. Now with a recovering Achilles break I was trying to avoid as much steep ground as possible. It’s why the long route suited me but I would have preferred the shortest way before that happened to me (on SP1).
Your 6-fig grid ref for the gate doesn’t exactly correspond with a field boundary but I have added it to my route page for possible future investigation. It’ll be close enough to find the gate visually and gain access to that magnificent cairn which, from a distance, I mistakenly thought was a ruin of some sort – sheep pen etc. I also now know where to start looking for the turn left - before the phone masts.
Useful advice.
Many thanks,
& 73, John
Jimmy M0HGY
Thanks Jimmy. A coincidence. The first time I walked over Great Shunner (outward bound 1968) I got thoroughly drenched too.
I agree; the people there are friendly. However they would be different people when you went there. Caz, Adam Lucy have only had the place a year and there has been at least one other owner since my XYL stayed there in the 1960’s and very probably several more. They have it pretty well sorted but are still learning how to manage the variability. The majority of people go there for one or two nights so they are more or less geared up for that. It means if you stayed a week or two, although it’s nice food and well presented, you’d run out of evening meal menu choices. Not an issue with me though.
We don’t take a dog ourselves but I like the fact it’s dog friendly. I ran out of dog treats by the end of a week. Like you and your Dad, we had quite a few Pennine Wayer’s pass through. On the last night there was a large family doing John o’ Groats to Land’s End via the PW with two Labrador dogs and they were joined by their friends for the PW part of it. They were raising money for brain cancer. £20k so far. Great effort!
There was also a chap running the PW. Evening meal is served up to 19:30. He arrived at 19:29 wanting a meal. They weren’t too happy but in the end it didn’t matter when he explained that he just wanted a plateful of green beans. Must have been on some kind of diet. Apparently off he ran at 05:00 the next morning. PW at speed on green beans! There was a girl from Israel but she was on the Coast-to-Coast having just come over Nine Standards. We had a good chat about that then moved onto the Peace Ship but unlike me and your Dad, she’d never heard of Abie Nathan. Much too young I suppose.
Anyway back to SOTA one pointer’s. You fooled me with Drake Howe until I found the other name Cringle Moor which is on the Lyke Wake Walk as is TW1 which I have done twice. Once by driving all the way up Rudland Rigg and then I went up from Clay Bank the second time. I avoid NYM in summer if I have Finn with me. I’ve seen far too many Adders over the years. I did do TW1 with Sasha but strictly controlled her. The S2S I worked on TW1 from NP26 had gone up from Chop Gate (or Chop Yat to the locals). A couple of years ago, I was heading to TW5 on a journey back from Boston but then the heavens opened.
I did look to see where Sharp Haw was before this holiday but it was down Skipton way as I remember. Didn’t look too bad though. A track around it. I don’t think I’ll be doing that conical Dufton Pike but I’ve seen it many times from the A66 and once walked up the track on its east side. Could have been where G4OBK lost his dog for hours?
Thanks & 73
John
Gerald G4IOG,
No nothing special but with summits, I find it very hard to tear myself away when I’m at my happiest. Usually it’s the time limit that makes me go or that combined with no more bands to try or chasers or the battery going flat of course.
Thanks Gerald – the foot doesn’t feel perfect but to be fair neither of them did long before this. I think it was David G0EVV in response to my pessimism immediately after the injury when I was looking at really easy ones, ‘Oh I think you’ll be able to do a bit more than that,’ he said. I barely believed him at the time but I’m working on it and hoping he’s right. After all, I have managed 8 points this year! Wow! but I’m very grateful.
I hadn’t noticed your keying until you mentioned it beforehand. You send great Morse. Geoff Pritchard would have approved of you. He lived in Scarborough and was the deputy chief Morse examiner for UK under Roy G4SSH. He never used anything else but a straight. I gave in and now I’m hopeless on one so keep on it is my advice. Can’t be easy in the cold though.
Thanks for confirming the route Andy described. I went for the easy and safer option. Safer in two ways. Fewer steep bits and to eliminate the unknown, such as dead ends, barriers or private notices and the like. Now I know I have the option to try it if I ever want to bag the summit proper. Talking of the summit, your photo was a revelation. I thought I’d read somewhere of a tiny cairn but what I mistook for the remains of a ruined building and dismissed turns out to be the summit cairn! Wake up John! What a cairn though.
Ah yes the RF black hole. After reading your words, my apologies go to Kisdon. However, I see you were wiggling side to side big time and I was up and down small time. Almost no one has a vertical beam for FM but with SSB/ Horizontal many of the dedicated ops have beams. There’s a theory that horiz gets over hills better. Also there’s no need to complicate matters with the feeder route. It’s vertical for FM because of mobiles I suppose but it’s limiting as well as inefficient. I have 3 or 6 ele 2m beams but my driver, the IC706-2G, needs attention. Either that or take the QRP 817 so it’ll likely never get done. You did very well from there in 2010 and proved what’s possible. Trouble is it’s not only 2FM that’s on the decline but SSB too? Long ago you could call on .300 and have an evens chance of a reply.
It seems to me that getting over high ground with VHF is as much about standing as far back from it as possible as the height of the ground. Almost like giving the RF the chance of a run-up. Just my way of thinking of it.
I did go back there on the Friday afternoon 24th Oct. I’ll post a report on that soon.
Thanks for the inspiration – nice photos too,
73, John
Thanks to everyone and the liker’s too
John G4YSS
Reports:
NP26-VHF – soon
NP6-VHF – sometime?
You’re right, it doesn’t. I shouldn’t have truncated it so much. Looking again using Google Maps satellite view I can see the gap in the wall (where the gate is) just to the right of those old stone sheep pens. It’s at NY 89593 00203 (54.39719, -2.16179).
Thank you Andy, Now we’re cooking with gas - if I go back that is and if the injury allows it. Many thanks to you and also to Google Maps satellite view. I tried to find a grid ref for the phone mast to help give context but failed so with this new grid ref, I won’t need it..
73, John
(C) 2025 Google Maps
I’m not sure from this satellite view exactly where the gate to leave the 4W road is but it’s somewhere along the red wavy line. I’ve circled in red where the gate in the stonewall up the hill is. The heather has been cleared in a few places and I followed some of NW-to-SE going ones to make the walking to the summit easier. The summit is at the red drop. The mobile base station is circled in green.
Disclaimer: As I deleted my actual route from OS Maps, this is based on my memory and the satellite view.
Oh don’t worry about that Andy. I take it as I find it and it’s not critical.
That picture helps a lot. I can relate it to the map. There’s enough info there to start looking for the turn left off the track from NY89375 00333 370m through NY89380 00283 380m and maybe a bit beyond. With the gate position nailed (within Google accuracy limits), if I can’t find the way from that I must be blind. I created a 1.1km route from this (as against 2.3km) and if I ever go back and am up for it, I’ll have an investigate at least.
Thanks again for doing the work. All is much clearer now.
John
This is actually SV2OXS a regular chaser from Greece.
It’s good to know I’m not the only one who confuses S and H!
