F/CR-109 - TM15SOTA
Hi all,
You can find an TM15SOTA alert for the next Saturday 19/11/2022, I will active the Mourre Nègre F/CR-109.
The weather forecast looks good at the foot of the summit, the temperature felt will be lower and the wind stronger at the top.
HF activation won’t be a problem, I will still test with my Arrow II antenna on 145.525Mhz & 433.500Mhz, hoping to find EA3 and EA6 stations :wink: Other are welcome ! (look at SOTAWatch spots).
It seems possible, here an example with Palma.
Here you can see a simulation made with the Radio Mobile Online site :
https://www.ve2dbe.com/rmonline_s.asp
Hoping to contact you :four_leaf_clover:
73, Éric
F5JKK
I will try and listen for you. Are you trying FT4 on HF? Good luck with the activation!
Hi John,
I think I don’t have time to do FT4 :frowning_face:
I look for you maybe on 20 CW or SSB.
73, Éric
Hi all,
An other info:
If you’re interested in trying out VHF or UHF, I can change polarization (vertical or horizontal) in an instant with the Arrow II antenna.
Please, you can put it on a spot in cluster.
73, Éric
F5JKK
Thanks for QSO ! best 73
Hi John,
In the log :+1: :crazy_face:
Thanks QSO.
73, Éric
Nice surprise Bob many thanks :+1: :wink:
73, Éric
Salut Éric
Alors cette antenne VHF/UHF ?
Salut Roger et merci pour le s2s :+1:
C’était un complete pour toi ?
Je ferai un petit CR d’activité où tu auras des infos sur l’Arrow II.
73, Éric
Thanks to all chasers and s2s.
I did 157 QSO this morning but I had to QRT because raining.
See you next activity
73 Roger
Thank you Éric, 20m was the only band I could hear you on. I hope you had a good activation.
John
Pas un complete mais un QSO avec un bon copain :stuck_out_tongue_winking_eye:
