I wanted to wrap up the year activating the Lug, the highest summit on the East Coast at 925m ASL. Partucularly as I’ve never managed to hike it earlier during this year. The forecast was okay’ish, with my only concern of fairly strong wind and lowish temperature.
I’ve started reasonably early, arriving at the Western carpark at 09:30 sharp. I’ve climbed the Lug few times before, but from the Eastern slope. The Western side meant to be easier so I was kind of relaxed and in no rush. Disgracefully, it took me slightly over 3 hours to get to the summit, providing Eastern ascent normally took me 2h 15min that is something to think about …
On my way up I’ve heard @EI3IX/P from Blackstairs EI/IE-006, my TH-F7 wasn’t fully charged and I had some hard time to get a QSO with Joe, but we’ve made that finally.
Getting closer to the summit the wind started to get heavier, to the point that I’ve started to concern about the overall activation idea.
It would be a serious waste of everybody’s time not to try at least something though, so I’ve started from my VHF FM routine (3el Yagi and 20W). It was freezing cold at that stage already, with ice starting to build up on everything. Nevertheless, first QSO with Don @GW0PLP and 5 more in minutes!
Next, a critical decision needed to be taken - to try 20m or not. With heavy winds and icy condx the idea didn’t look great, but curiosity has won ![]()
To set the mast up and run dipole ends was fast and easy, until I’ve realised I’ve never connected the cable to the feed point
The mast went down again, feeder connected, up again. A seriously pleasant surprise was to find SWR spot on after all!
CQ SOTA several times and nothing! Ups … 5 Watts only, no time to play with QRP under weather like this! Crank up to 50W and CQ again. Now we are in business - 19 QSO in 17 minutes! I found my straight key is very good with winter gloves ![]()
Next moving to SSB and after a self-spot 20 more QSOs in the log!
I’ve spent on the summit around an hour, my thermometer showed exactly 0C and ice layer has built up on everything, around 5mm on antenna wire and guys, a tripod and even the rig was iced all over. Now I know what “all assets frozen” means! BTW, I’ve used screwdrivers as pegs, worked as a charm!
That’s All Folks
Happy New Year de EI4JY
Short video clip to get an idea on operating condx
