Tomorrow I go to EA5 for two weeks and hope to activate there some summits.
The first one will be likely EA5/AT-039, hopefully on Wednesday.
Band of operation will be mainly 20m, mode CW.
Equipment will be FT817 with LiPo accu (11.1 V) and 2x7.5m doublet with tuner.
I don’t know if I can set alerts before the activations, so stay tuned.
I hope to go up at least every second day.
Hope to work you.
73 Reinhard, DK1IO
In reply to DK1IO:
Good luck ! I will try to listen for you.
Martin df3mc
In reply to DK1IO:
Thanks for the info Reinhard.
I hope to work you from EA5
Roy G4SSH
My mountain climbing is finished now. 7 activations, 6 of them first ones. All where exhausting, some dangerous. Compared to the mountains at home the points for the summits here in EA5 are ridiculous low.
Thanks to all who called me, sorry for those which did not get through.
Next activations will be from DL, later in July from S5.
73 Reinhard, DK1IO
In reply to DK1IO:
Thanks for the QSO’s Reinhard, pleased to work you from our gw holiday chalet nr Aberdovey using the PFR-3 and W3EDP ant {bit of wire out of window & over the roof}.
Sorry not to have made a S2S maybe next time…
73 and have a safe journey home,
Mike G0BPU {GW0BPU/P}
In reply to DK1IO:
Hi Reinhard,
Thanks for the activations, managed to work you on three, hope you had a great holiday and I look forward to working you from DL.
Best Regards,
Steve…MW0BBU.
In reply to DK1IO:
Thank you for the 7 activations from EA5 Reinhard. Your choice of 14061 KHz was much appreciated by chasers and I was delighted to have contacted you on most of the SOTA’s.
The last two contacts was whilst I was on holiday using a small indoor vertical antenna, so your FT-817 was doing a good job.
I hope to hear you under your own call again before long and look forward to your next trip to S5 in July.
Roy G4SSH
