Yesterday, while activating W4T/SU-055, I worked EA2IF at about 1917z on 20 meter CW. That contact put him over 30,000 chaser points. Join me in congratulating Guru!
Thanks for all the contacts so far and hope to work you many more times.
Congratulations Guru on your 30,000 chaser points. I was also happy to work you on your activation on 2/11/19 , on EA2/NV-151. That was a really good day for working the EU sota. We must have had a mini- sun spot episode. Between 1500Z and 1600Z I worked 10 EU activators. Things are looking up! All the best to you. de Scotty KG3W
Congratulations, Guru, and thanks for all the chasing! When I activated W4V/RA-004 yesterday and worked you, it must have been just before the QSO that put you over the top. Glad to help!
Scott WB8ICQ
