EA2/NV-068 stormy activation
Hello,
Today I took the chance of doing an afternoon activation of Baratxueta, and after a quick lunch, I headed to this nice summit, 45 minutes drive apart from home.
Ascent is short through a beautiful beech forest, now in bright & fresh green colour.
It was pretty hot, abt 30C and there was no wind in the summit.
Today I deployed a Doublet antenna to be able to do quick band changes with my Z817 autotuner. In the very summit a group of goats looked at me and approached little by little. I used my mountain sticks to chase them out but they were stubborn, and when one started chewing part of my antenna I decided to jump over the fence and find a safer point.
When I started the FT817 I heard a lot of static noise from a thunderstorm; not really in my area but somewhere around anyway.
That made the HF activation today really difficult.
After a short number of qso in 20m SSB including a S2S with GM4COX/P I moved to 20m CW. Some chasers requested several times to correct their calls, even though they were right in my reports, therefore I felt that there was severe QSB and the noise was also causing troubles to be copied all right.
I copied NE1SJ working SOTA, but although I tried several times to work him he didn’t copy me. A pity, but the contact in such conditions was also difficult at my end, with strong sudden crashes making difficult to copy the full qso.
I did some more qso in 30m & 40m CW and at the end the WX was changing, becoming more windy and dropping the temperature down. I decided to end the activation but I saw a spot from DL8DBW/P and we completed our S2S.
Thanks to all chasers and the S2S as well. It’s always a relief when you chase another Sota and wait to hear the other activator catching you among the chasers…
CU soon, VY 73
Ignacio EA2BD
In reply to EA2BD:
Well done dear Ignacio.
Fun story with the goats trying to eat your wires!
I have my station at home partly dismantled but even though I managed to chase you on 30m CW from home and later on 2m FM from my car.
It’s good that the storm didn’t finally chase you, :wink:
I hope you’ll be able to chase me tomorrow when I’ll be activating new unique Uroa Mt. together with Juan Carlos - EA2EEB.
Best 73 de Guru - EA2IF
Ignacio: Well done! Here was a bit risky because of the storm too, I couldnt hear you because scratches. Better luck next time. An for goats, better end feds… more volts on the end :wink:
Guru:
Tomorrow I’ll try (very stormy here also) to be at Oiz EA2/BI-009, to try S2S with Alberto at Hiru Erregen Mahaia EA2/NV-001. It’s a rare opportunity, and I hope Alberto to achieve it! We’ll try together as well, ok?
73 and GL!
Mikel EA2CW
In reply to EA2CW:
Dear Mikel,
A not ham friend invited me last week to go with him and some other non ham friends of him to Hiru Erregen Mahaia next June 28th and I accepted as it was a great opportunity to reach the highest summit in our NV area for the second time in my life (1st one was many, many years ago) as well as activating EA2/NV-001 for the first time for me.
That’s a long hike of about 7 hours total going up and back down.
I don’t know yet details but you are welcome if you want to join us. I guess we’ll be leaving home by about 7 AM.
Let me know if you feel like coming…
In reply to EA2BD:
they were stubborn,and when one started chewing part of my antenna
Hello Ignacio
something similar happened to me last year on a summit in Austria. I was just setting up my 10m mast and was concentrating on balancing the mast, when I suddenly saw from the corner of my eye that a cow has approached and has begun to chew the end of my dipole wire. Immediately I tried to shy the cow away but then I got a little bit panic, when I realized that the cow already swallowed a length of the cable. So I pulled very carefully the cable out of the cow. Fortunately the wire was very strong and did not tear off. So no harm has been caused to the cow; only to me because I had to use most of my drinking water for cleaning my dipole wire :wink:
Now I’m always very carefully watching out for any animals nearby the activation zone :slight_smile:
73 Stephan, DM1LE
In reply to DM1LE:
The first dipole I tried to construct in my garden fell victim to a fox. I went indoors to fetch something, leaving the wire stretched across the lawn, and came back a few minutes later to find the wire in many pieces. I guess the fox couldn’t resist what must’ve looked like the longest earthworm in history…
73, Rick M0LEP
