Hi all
If you use or are looking for a logging program that supports SOTA as a chaser, this is for you. I have been working with Dave Bernstine AA6YQ the author of DXLab. He has added support, if you click on a spot that has a SOTA reference# in it, it will place the SOTA reference in the logging window. That is one less step that you have to do when chasing!
He may add that when you click on a spot with a reference# in it it will also give you the correct heading for your beam.
If you like it be sure and send Dave a thankyou email!
Kent
N6WT
