DM/BM - 4 Summits in Bavarian Forest yesterday
After a two hour drive from the Munich Region to the Bavarian Forest and a little walk SWL Wolfgang and me reached the first summit, Zeller Hoehe DM/BM-300. 39 QSOs, highlights: N1EU and 4U1ITU called in.
We were activating Bernhardsnagel DM/BM-299 before lunch (40 QSOs), Hadriwa DM/BM-296 (28 QSOs) and Proeller DM/BM-002 (22 QSOs) in the afternoon.
On each summit 14/10/7 MHz were used. Started on 20m to avoid crowded 40m band.
Most contacts in CW with 100W from IC706 (had to reduce power at the end to avoid empty battery) and 2m long mobile vertical (Diamond C-Whip, vy fast installation), rig is described here:
http://www.sota-dl-alpen.de/articles/SOTA_equipment_DL2DVE.pdf .
The following very active stations made it more than two times into the log:
5x G4OBK
4x
DL2KAS
G4SSH
MW6GWR/P
OH3T
ON4FI
OZ4RT
3 x
DJ5AV
DK4MO
DL1FU
DL3HXX
G4FGJ
HB9BCB/P
HA7UG
MW6GWR/P
OE8SPW
PA0ALW
PA0WLB
S52CU
Nice S2S QSOs with HB9BCB/P and MW6GWR/P.
Finally 129 QSOs, a good day.
Thanks to all chasers !
73 andy DL2DVE
In reply to DL2DVE: good to see that the 4U1ITU call was appreciated. Our QSO added to my chaser score.
In reply to PB2T:
thanks a lot Hans, at first I didn’t believe my ears… 73 andy DL2DVE
