One of the regular questions that gets asked around here is how to delete an upload when people discover an error in it. Deleting has to be completed prior to reuploading or duplicate chaser entries will occur, or the upload will not be permitted in the case of duplicate activations. S2S entries need to be deleted in different locations, which makes things awkward and difficult if there is a large number of QSOs in an activation that were S2S and need deleting in order to fix them.
To smooth that over, I’ve just pushed a change to the database and API that provides a way to delete an entire upload in one go.
From now on, any updates via CSV or ADIF, or via the apps that support log upload, will be tagged as an upload, and be visible from the Manage Uploads menu, located under the Submit Logs menu.
From here, you can select uploads and delete them. If you delete an upload, all S2S, Chaser and Activation logs from that upload will be deleted. You can then re-upload the CSV or ADIF.
Please note that this will not pick up old uploads. Only ones from this point on. I know someone is going to ask “I looked at the page and all it says is ‘No uploads found’ and I uploaded something last week! Why isn’t it there?” and I may be forced to respond with withering sarcasm. Your old uploads will not appear. Only ones from this point on.
