Database Down last 2 hrs
The database is out we will wait hopefully its a simple fix
we appreciate the great work from the crew behind Sotawatch 2
73 de Rod VK2TWR
In reply to VK2TWR:
I have also experienced problems when trying to logon to database.
This is the red letters message I’ve got:
A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: Named Pipes Provider, error: 40 - Could not open a connection to SQL Server)
I hope it’s a temporary problem and we’ll have it back in shape soon.
Best 73 de Guru - EA2IF
In reply to EA2IF:Hi Guru yes have the same error coming up.
we get some very hard work out of the site and it is very rarely
a problem
Best 73 de Rod- VK2TWR
it didnt take to long the database is running smoothly again
thanks
73 de Rod VK2TWR
In reply to VK2TWR:
Seems OK now… they rebooted the server.
Now can someone reboot the WX , it’s raining cats and dogs here in the Gummers How cat park. :frowning:
MM 0FMF
Wow, a Scot complaining about a bit of rain!
If it carries on as per the weather radar it should be gone soon.
Gummer’s How isn’t like a Scottish mountain Andy. You don’t need to plan for a whole day and many miles of waterproofness. How wet can you get in 5 minutes? Take a bothy bag to give you shelter while activating and you’ll be fine.
Tom M1EYP
Is there a dog (and pony) park too? GD&R
In reply to MM0FMF: Hi Andy a quick and easy fix Thanks
Rod
VK2TWR
In reply to M0LEP:
Damn Android touch keypads! I’ve got the laptop working now. 30miles SW of Gummers How the WX is quite fine.
M0FMF
