I have been using this unit for extra on air time with my FT 817. Not only does it work for the radio, but it has a USB port for cell phones and a laptop port as well. It seems to last a good long time, and is very light. It charges in 4 hours which is not bad and claims 8000 mAh.
I’m also skeptical. Bear in mind also that the mAh of the battery is only half of the story. In this case it is likely that the unit contains a switching regulator and thus I would suspect that the battery is a 2 cell unit.
I have a bike light that claims an incredible light output (4,000 lumens) and it also has an “8000mAh” battery pack. In reality both the light output and the battery capacity are exaggerated. It’s still an amazing light though.
With most things, if it meets the purchaser’s needs at a price point that he’s happy with, that’s really all that matters.
Re Walt’s post; most people have a Lipo battery in their trouser pocket.
pocket.
But perhaps not an 8 Ah one!
As I have mentioned previously, having had the unpleasant experience of a LiPo battery bursting into flames in my car whilst I was driving along, I treat them with the utmost caution!
I am very skeptical about the safety of the charging and voltage regulation arrangements specified for the battery mentioned by the OP. I wonder if this device would be able to obtain “CE” certification.
I used this unit with the built in battery on the FT 817 for about 2 hours and it never even came off of the top bar of the level meter. Do I really think it offers 8000mAH? nope. Did it work for what I needed and was very light YUP. and I can use it for other charging needs too. That said, I will carry a SLAB for when I am running my FT 857.
It never hurts to have tools available for any situation. YMMV.
Maybe the Energizer XP18000 would be ok for my FT857.
18000mAh at 5 volts -> 7,5 Ah with 12V…
No so heavy like the sla…
But I think a better first purchase is a battery booster like the MFJ-4416B.
Grettings from DM/RP de Joerg
I have been using this battery for over a year now for SOTA activations with my FT-817. So far without incidents, but I never attempted to charge it in a car One of the numerous plugs supplied with it fits the FT-817 perfectly. Overall highly recommended, but - as always - YMMV.
Since it accepts input voltage up to 19V, it can be charged by a solar panel. Learned about it from K0MOS at My Radio Equipment | SOTA outings by KØMOS and contributors
I tested this setup a few times and seems to work all right. However, despite carrying a foldable solar panel on many activations, I never charged the XP8000 in the field from it. Usually I run out of chasers before the battery voltage drops low enough. One of these days I am going to attempt a multi-summit hike, and then this solution might come handy.
I just use a 12v to (for me 120V) inverter to power the power charger that came with the unit. I should be good to go.
And agreed, I usually run out of chasers. I am, however, looking at doing extended hikes next year on the Appalachian Trail, where there would be ZERO power available. So the solar panels might come in handy. Or I have a handful of these little units.
I am still gaining knowledge on how to pack… and better yet, what NOT to pack.
I would very much like to see how others are packing. I go to many of the SOTA blogs, but no one shows how they pack their stuff.
Lets continue to exchange informaton as it appears we are on similar paths…if you will … heh
