If you log onto the reflector, and look for your alert, you will notice it gives you the option to edit it. Once you select this you can change anything in the alert, including the date.
Hi Andy,
With using todays date and an early morning time, you effectively entered an alert in the past. You are correct the Alert list does not display alerts in the past.
You’ll need to re-enter the alert record with the correct date.
