Correcting old SOTA QSOs
When performing a quality check on my computerised logbook I discovered that I had worked Feri HA7UL/P on 2m FM in 2012 HA/KD-034 and on 2m CW in 2011 HA/KM-019.
These were logging errors - the SOTA QSOs were actually made on 20m and 30m CW not on 2m. After checking the QSOs in Feri’s SOTA database log for the two summits concerned which showed the contacts were made on 20m and 30m I deleted my 2m contacts with a view to re-entering them showing the corrected bands.
As the screenshot shows I am unable to do this as the QSOs are more than 10 years old, how dissapointing!
73 Phil G4OBK
This is just a guess, but it might work if you make a CSV file and use the Import CSV method.
There was a reason there was a limit. I cannot remember what the reason was.
You can upload the chases with today’s date but all the other details as-was and let me know the old dates and I can whizz over them and push them back in time for you.
Thank you chaps, I will try both methods.
73 Phil
Thanks for suggesting that workaround Tom - successful! I won’t need to bother Andy. The import CSV works with QSO entries older than 10 years. Contacts restored.
73 Phil G4OBK
Wow, for a moment there Phil you had my “extreme jealousy” nerves jangling! :joy:
