Same here. Had to fill this in even though the alternate is the same as my only call.
Same here:
I even added HB9DBM/p, which did the trick also.
Since I never saw this Chassed Thing I’m very glad such a thing exists, hi…
I have filled that field with all these callsigns I’ve been using over time (EA2IF, EA2IF/M, EA2IF/P, EA2IF/1, AM02IF, F/EA2IF/P, CT7/EA2IF/P) and I can now see the Chased By You On
I didn’t realise that my own callsing with different preffixes and/or suffixes was seen by the system as different callsings, therefore I never felt I needed to fill that field. Also I had completely forgotten about the special preffix AM0 we were authorised to use when the King Felipe VI got to the trone of the Spanish Kingdom in July 2014.
Thank you, Jon @GM0ZFZ for giving us the solution and Martin @OE5REO for having raised the question which led to the solution!
Guru
Jon, do I need to fill in all the variants such as /P, /M for each callsign, or does the software recognise those as the root callsign?
Also is it just variants such as G6xxx & GM6xxx, or do I also need to add any prefixes I’ve used eg EI/G6xxx.
The software should handle this without you needing to put in the suffix variations of your call. Same with prefixes. However, from the comments in this thread I do wonder whether the My Chases section at least might not quite be working … I’ll need to check it out.
