Carn Daimh GM/ES-052 - 7 bands in the sun
Carn Daimh is a 2 pointer just North of Tomintoul and was my first activation for some time due to a combination of poor weather and knee problems. Weather was first class, knee not so great but it didn’t complain too much. This was also a first outing for a new-build Moxon for 6 and 10m which I had only tested in my garden.
Route up
I started from Glenconglass “car park” just North of Tomintoul - room for about 5 cars by a Glenlivet Estate map board and used the anti-clockwise part of Route 6, shown on the map. This route is also described on the Walkhighlands website.
Estate map
Route map -detailed ©Crown copyright 2022 Ordnance Survey. Media 041/22
From the parking area, walk through Glenconglass farmyard and go through a gate into a field immediately on the left. On the day, this contained a herd of longhorn heifers, minding their own business. Cross a small stream by a wooden footbridge and a marshy area which has had planks laid down, then walk up to a stile at the top of the field.The next field contained sheep.Follow the fence line to the right - there is a faint path in the grass. The trees shown on the OS map have been felled.
Looking back towards Glenconglass
There are 2 gates with spring-locks and chains, easily negotiated, which pass into an open area of bracken and heather, with more sheep.
Here I lost the path, although I did find a waymarker with no obvious path attached.
I just kept to the grassier bits to the South of the streams until I saw a marker post for the Speyside Way and headed for that.
The Speyside Way path is obvious and takes you all the way to the summit, first through another gate into a fir plantation which is located at the gap in the trees shown on the photo below.
A short way after the gate there is a large signpost - follow the path which goes up left, indicated on the post as Ballindalloch. This goes all the way to the top.
The summit is marked with a large cairn and a compass rose viewpoint guide.
Looking NE towards Ben Rinnes, GM/ES-021
The walk took me about 1 hour 45m
Activation:
857d
Moxon for 6/10 plus mast for 40/20 linked dipole, 17/15/12 delta loops and 2m loop
I started on 2m FM, giving Mike MM7MWL a Complete. MM1FAS, Richard in Elgin then called in, but a spot and 5 minutes of CQs brought no further contacts - the limitations of a simple loop I guess.
Checking 6m I heard the GB3RMK beacon blasting in, but a spot and a lot of CQs brought nothing.
Moving to 40m brought a run of 17, mainly UK, including MM7MWL again and a S2S with MW0JKS/P. EA2CKX was the only non-UK.
On 20m a spot brought 14 chasers, with Chris F4WBN his usual 59+. HB9GKR/P was a second S2S.
I checked 6m again and a spot and calls brought silence, so I chased a couple of summits on 40 and 20 before trying 17m. A spot brought 10 chasers, including F4WBN again and 2 S2S. Dinos SV3IEG was my furthest East of the day.
On 15m, F4WBN got me for the third time, followed by 3 others including S57S/P for a S2S.
12m was dead as was 10. I checked 6, but again nothing but GB3RMK.
Went back to 20m and chased 6 more S2S.
Another spot on 17m brought a second S2S with HB9HTM/P and 3 others; by this time it was 1530 local. I had hoped for some Stateside chasers, as there were some strong signals from the East coast, but no.
Checking 10m I heard a CX8 looking for German and Swiss stations, so I quickly changed out the 6m mox for the 10m one and a spot brought 7 chasers with an interesting geographic spread: EA3EVL, EA7GV, LW2DO - best DX of the day and my first SOTA QSO with Argentina, EC8ADS, EA3HP, EI2JT/M and M0BHG.
After starting to pack up, I had a last look at 6m and heard F5DE calling CQ in CW but he faded out. A spot and CQs finally brought some contacts: F4EUL on Belle Ile EU-048, EA4HVS and GM4MOX in Tain off the back of the beam.
69 contacts for the day, which was gloriously sunny with just a gentle breeze. 360 views from the top were great.
During the day there was a steady stream of walkers passing through and about 20 bikers as there are also biking trails which include the summit. I also met the estate warden with dog who was walking around checking fencing.
Picnic bench on the North flank of the summit - probably just outside the activation zone.
Thanks to all the chasers and activators and see you again soon - I’ll be in Croatia from June 4th-19th as 9A/G4JXP/P.
Many thanks for the quick contact on 40m Simon and the potential for a Complete in the future. The route looks like a great one for a winter bonus activation, maybe early December before the winter proper arrives.
Ah, so thats how to get up there. I climbed from the east, having done The Bochel GM/ES-066 earlier in the day. A most unpleasant ascent over cow trodden mud followed by post-holing through snow. A different descent line was a bit better, but involved walking for 1km down a track completely covered in water ice, with a smearing of sheep crap on top. Your way seems a lot more pleasant.
Well done on the QSO’s and the antenna farm. Enjoy Croatia. We’ll need to try for a summit to summit or two.
Yes, I think the route should be OK even in snow, Gerald. No shelter at the top though - I talked to one of the bikers passing through who said the last time he’d been at the top, he’d been blown off his bike.
Ah, I did wonder about your comment on the Deeside Sota Whatsapp group :smirk:. A S2S from 9A would be nice.
If you want to know the best routes up Cairn Daimh ask your friendly Awards Manager . I used to live very close to that hill and if was my first SOTA activation
Go on then Barry…
Past my previous house, take the track left before the quarry follow your nose to the summit - can all be done by Land Rover. Would give you a map but nothing available here in CT3 :wink:
