I would say no. Iron dust cores, such as -6 mix, are used to make high-Q inductors. Ferrite cores, such as -43, are used to make wideband transformers or chokes. They are not really suitable for inductors.
okay thx good to know!!
Julian
The toroid in the AX2 as pictured by @W7ETF Steve is an unusual one, it’s painted to indicate -6 material but has the height of about four T-50-6es all stacked. Any idea what this is? It seems that other short base-loaded whip experimenters have had success with conventional T-68-'s…
The original coil core looks like a T51-6 (e.g. Micrometals).
In order to avoid the somewhat tricky soldering work during the modification due to the limited space and to enable a problem-free fine spread of the windings to set the desired resonance frequency, I use 2 stacked T-50 toroidal cores as a “replacement coil core” (Mix #2 for 14 and 18 MHz, Mix #6 for 21-28 MHz), wound with ECW 0.63 mm (AWG #22).
By the way,
The improved stability of the BNC connector on the AX2 compared to the AX1 motivated me to “retire” my AX1.
My small (finger … and backpack friendly) loaded all-band antenna with the existing 60/40/30 m extender includes now
AX2-20 (for 60/40/30/20 m)
AX2-17 (for 17 m)
AX2-10/12 (for 10/12 m and (together with LC30m) 15 m)
2 guyed radial pairs of 2.5 m (for 17-10 m) and 3.1 m (for 60-20 m)
Tripod (for all seasons/earth surfaces …)
Selfie stick allowing a feed point height of approx. 0.85 m
Note: I noticed with my AX2’s (when new) that the hexagon nut on some examples was only tightened hand-tight and in one case it was even loose. The result of this: The antenna wobbles about like the AX1 or a little more …
Heinz did u print the cases with your 3D printer or are these the original plastic cases?
Julian
… if I remember correctly, there is no 3D printer in our household …
Ahh okay got it haha.
It looks easy to make the antenna with an 3D printer and a BNC plug.
How is the performance of your AX2? Did you made “good contacts”?
Julian
Dear Heinz,
Your neat whip antenna extenders, as for any of your homebrew gear, are precise as a good Swiss watch!
Thanks a lot for sharing your detailed info. I also like that tripod which seems to be lighweight as well.
I’m in the process of building something similar here. Christmas will bring me a whip to play a bit with…
73 Ignacio
Thank you Ignacio.
The main motivation for building this little and, above all, very handy antenna came from the fact that my fingers/hands had been plagued by tendonitis over the last few years and required some annular ligament operations (still a few pending …).
I hope to see your smiling face soon when your short whip also captures the signals from well-known SOTA dx stations (e.g. from ZL, JA, PY, LU, W, VE, …).
For my part, I would also like to use my little whip to try to exceed the previously achieved distance of 992 km for an s2s QSO in the 60 m band, hi.
73 gl, Heinz
