A sincere thank you to everyone for your help, My next plan of action is to build a 70cm collinear and try it on my existing coax to see if it works for the DMR repeater , at least that way if it does I will be able to use it for 70cm analogue repeaters as well rather than a dedicated beam and I will not have brought coax for no reason if it fails. I have been calling on simplex DMR. In the past I have not thought much of DMR because of it’s reliance on the internet and the low audio quality audio that I had heard from the HUBNET system (running through a multimode system). Having now heard the audio quality/lack of noise on a S1 to zero signal I have to say I’m quite impressed and can see it’s potential ( although everyone else seems to have already explored this !) Next plan is a sota summit ( Titterstone Clee, I walk my dogs there regularly) on DMR !
G7SKU may have gotten in however on the screenshot it shows he is trying to use talk group 16777215. This is the all call talk group that is for obvious reasons filtered from the network.
@G7SKU You need to program a contact and set the channel to use that contact. TG91 always has people blabbing away. You can try TG2355 (Scotland wide), there are always people listening on there.
You will know if you are getting in as the radio will blarp and say repeater not found or something similar if you cannot connect.
For a simple test, create a channel for your repeater set to time slot 2 and the contact as a private call to 9990. This is a parrot test call that will play back to you whatever you say into the radio.
I worked this out in the end and had thought all calls referred to who could call me ! I’ve had a chat with the repeater keeper and in all reality I don’t think I have a chance of improving the signal to the extent I need. At the moment at best I’m at -120dbm and this fades lower in an almost mobile flutter type way ( not sure what is causing this flutter !) I have tried taking the radio out in the car with the same type of antenna on the other side of my village , this eliminates the immediate buildings, the close rise of land and gives me about 3 to 4 miles line of sight before hitting another rise in land and no improvement was seen. I did think of making a gateway and buying another radio but then realised this would tie up another Laptop and stop me using other repeaters and simplex due to desensitising of the radios both ways ( not that there is much to hear !) My plan is to pack the radios (ham radios) away concentrate on PMR446 and trying to get a good signal from radio Caroline on 648Khz as I find I’m wasting time and feeling totally frustrated with the lack of activity on the Ham bands !
I’m not sure it would make much difference ! At present using repeaters from near Bridgnorth Shropshire I can reach as far as Oxford, Gloucestershire, A lot of Herefordshire, Worcestorshire, Warwickshire , over to the Welsh boarders and the Black Country and Birmingham. Using some these repeaters I have tried connecting to other repeaters ( using Echolink) around the UK and still it is quiet. the Cornish repeater GB3NC used to be quite busy when I lived down there but as yet I have never heard a whisper much the same with the others the one that seems to have the most activity I have to say is GB3XO in Redditch but even that can be quiet especially in the week ! I’m not saying no one is on them but even on a weekend you can call for hours with no reply !
With a colinear on your roof you could almost certainly hit a DMR repeater somewhere. DMR, specifically the brandmeister network is where the action is at these days.
If you cannot hit a DMR repeater for odd reason, get an MMDVM hotspot connected to an antenna on your roof and make a simplex gateway that covers your town. <5W and no NOV is required.
Non-internet linked FM repeaters are for the most part completely dead. The only exception I have heard is the venerable GB3ED in Edinburgh who’s unofficial keeper of the watch @MM0UHR will happily welcome any M7 into the club.
We have the opposite here, a local DV repeater (10-12 miles away has now been re-instated as an Analogue and C4FM repeater after it and it’s 2 meter sister faded into disuse (Would have been ideal for me on DMR ) So far it has been really busy with stations from the Shropshire villages reporting better coverage than the 2 meter repeater on the same site.The reappearance/reinvention of this repeater has prevented me from packing the gear away. I did think of the gateway option but decided against it as this would mean buying more gear, it would still rely on internet rather than radio, mobile access due to the rolling hills would be poor and it would also prevent me from using other modes ( analogue) and locally the experiment was tried and failed. PMR446 has also given me some hope with some amazing contacts over the weekend. With a couple being over 50 miles from my little 0.5 watt handy with a 3 inch antenna clipped onto my open car window ( admittedly from a good height) The band was totally jammed with people. Hopefully this and the reinvented repeater should keep me busy. Tomorrow I will be checking coverage from it on my two different routes to and from work.
The DMR Radio for me has not been a success but it will work on FM and has good airband coverage so will live in the cupboard as a back up, at least it didn’t cost much.
