Activation EA8/GC-003 Moriscos
After the exertions of Saturday on EA8/GC-013, today could be described in the vernacular as going “from the sublime to the ridiculous” (well ridiculously easy).
Saturday’s summit was 8 points and over 7 hours for 8 points.
Today was 10 points, with barely 20 minutes walking and an hour of radio including set up and packing away.
I followed the instructions from Luc @ON7DQ and drove up the gravel track to the highest possible parking spot. This is easily negotiated in a normal car. The only very small issue was the drainage channels which are quite deep and need to be tackled slowly.
The parking spot is marked by one of these rather wonderful wooden signposts which seem to be relatively new and everywhere in this area.
From this spot it was a 10 minute stroll to the summit on the forest road that continues all the way to the top. You can’t drive this section as there is a locked chain across the bottom of it, just beyond the parking area.
Without the chain you could easily drive a normal car right to the top.
There was sign of wildfire activity alongside the track and a distinct smell of fairly recent burning.
Once on the top I found a comfortable perch and initially set up for 2m SSB. I was pleasantly surprised to get three fairly quick contacts, 1 on GC and 2 on TF.
2m FM yielded nothing and I wasn’t of a mind to hang about too long, so after 5 mins of calling I rejigged my location and added the EFHW to the mast to work some more stations on HF.
In the end I got 18 x 20m SSB and 4 x 15m SSB.
I started to feel some rain drops and decided it was time to pull the plug and not explore any more bands.
Equipment:
IC-705. SlimG 2m SSB and FM (both omni vertical), 40m EFHW for 20m and 15m. Carbon 6 pole.
The only downside to the whole thing was the poor visibility. Tim @G5OLD informed me that a Sahara dust storm has blown in and is set to get worse and peak on Wednesday. This happens many times each year and the PM10 particles can be hazardous to those with breathing issues.
More info here:
Thanks to all the chasers as always!
Good to get you Gerald, looks a nice summit
