Claife Heights
|SOTA ID:| G/LD-053|
|Height: |270 m (886 ft)|
|Grid ref:| SD382973|
|QTH Locator:| IO84MI|
|Lat: 54.367315 |Long: -2.951298|
Claife Heights is a very different summit this year following Storm Arwen! The forest around the summit is now all felled and there are only a few lone trees left. It’s really quite depressing as the woods were lovely there. The view from the summit, which used to be a sneeky peak at the Howgills and not much else, is now almost 360 degress.
The bands were in excellent condition today, especially 10m which was wide open. I could hear a Turkish station on 10m FM for example. I had limited time as the weather was due to come in. Today I was using the IC-705 with Chameleon MPAS2.0. It was showing high SWR on 40m, so apologies for me moving on quickly. I need to check everything as I had the same issue on High Street recently.
I timed the ferry just right both on the way across Lake Windermere and back again. It is £2 each way on a motorbike, bargain!
Regards, Mark.
TIME | CALLSIGN | BAND | MODE | RST | RSR | OPERATOR | SIG | REF |
12:50 | 2E0XLG/P | 2m | FM | 57 | 57 | Chris | ||
12:56 | OH3GZ | 20m | SSB | 59 | 59 | JUKKA | ||
12:57 | OE6RCD | 20m | SSB | 59 | 55 | ROLAND | ||
12:57 | M7MCG/M | 20m | SSB | 55 | 55 | Micah | ||
12:58 | EA2DT | 20m | SSB | 53 | 42 | Manuel | ||
12:59 | DM1DF/P | 20m | SSB | 55 | 55 | Daniel | SOTA | DM/BM-352 |
12:59 | DJ5AV | 20m | SSB | 59 | 57 | Michael | ||
13:00 | F4FTJ | 20m | SSB | 59 | 59 | Thomas | ||
13:01 | EA3EVL | 20m | SSB | 55 | 51 | PABLO | ||
13:02 | HB9CGA | 20m | SSB | 59 | 57 | ULRICH | ||
13:04 | HB175RAIL | 20m | SSB | 57 | 57 | c/o | SOTA | HB/SO-010 |
13:08 | IT9GSZ | 10m | SSB | 59 | 56 | Nunziato | ||
13:11 | LZ1WR | 10m | SSB | 59 | 59 | Todor | ||
13:18 | EA3EVL | 17m | SSB | 59 | 59 | PABLO | ||
13:19 | OE5REO | 17m | SSB | 55 | 33 | Martin | ||
13:21 | HB9HOR | 17m | SSB | 59 | 55 | Roger | ||
13:22 | HB9MKV | 17m | SSB | 59 | 52 | RUDOLF | ||
13:26 | S57ILF | 17m | SSB | 59 | 55 | FRANCI | ||
13:26 | EA3EVL | 17m | SSB | 55 | 55 | PABLO | ||
13:31 | S58WW | 20m | SSB | 59 | 59 | Primoz | ||
13:37 | SV3FUP | 10m | SSB | 59 | 55 | ARIS |
For comparison, this is what the view from the summit used to be like in 2018:
and the woods on the approach:
