Hi Andy,
It is good to have a discussion on a future challenge but perhaps it should have it’s own thread? Unless of course the next challenge is similar to the 12 m one but on half the wavelength.
The 12 m challenge as you created it was to promote the use of 12 m for SOTA. A very good idea to make use of a neglected band that could be accessed with easy to build antennas and one that was on most transceivers. Also the sunspot activity was expected to yield global dx. Well the challenge has been a great success. I congratulate you on a fine idea. It will be hard to get a replacement as good.
What to do to replace it? Well I have to say none of the ideas floated so far have ignited my imagination.
There is a saying, if it’s not broke, don’t fix it. I know you may be bored with the 12 m challenge, but as the sunspot activity declines it will be more challenging, but not without its excitement.
Maybe you could cobble a line or two of code so the next one is the 2015 12 m challenge that runs for the whole of 2015. Then the 2016 challenge could run for the 2016 calendar year and so on. That gives a 6 month break for the weary 12 m warriors before starting a new series of challenges. The solar cycle has a few years yet of dx for 12 m and there will always be sporadic e on that band.
I know there has been some muttering in the ranks because 12 m is not available to all amateurs. Such divisions have always existed and the only fix is to upgrade. At least 12 m is available in most countries, unlike 4 m.
I sniggered at your little joke about using FM because it drains the batteries faster but some folk might take it seriously. They might want us to use lead acid batteries, valve technology and steel masts, and 160 m only, just for the challenge.
If inclusivity is to be part of the next challenge, don’t forget half the world is on the other side of the equator and the seasons and sporadic E peaks are 180 degrees out of phase with bonny Scotland. A 2 month time scale based on “summer” in Scotland would be more of a lock-out than a challenge south of the equator. Not that I am against a region based challenge but to date SOTA has been available world wide in all its facets.
Returning to 6 m.
Like 12 m it is under utilised for SOTA. It would probably be the next best alternative to another 12 m challenge. Because of TV and other services and local licencing rules it is not available to everyone without restriction. Also it mostly will be useable for troppo and single hop E’s, further restricting QSO probability. But antennas can be lighter and smaller than for 12 m.
That’s my 10 c worth.
Ron.
