5.000 chaser points
I have just passed 5.000 chaser point’s, I would like to say a big thank you to all activator’s without all your hard work this would not be possible best 73s
sean mw3pzo
In reply to MW3PZO:
Well done. I have often heard you.
What next? 8)
Best wishes
Mike G6TUH
Congratulations Sean on achieving 5,000 chaser points.
Jimmy M0HGY
In reply to G6TUH:
In reply to MW3PZO:
What next? 8)
Going for the 1.000 uniques 213 to go hear you alot also even om 20mts sometimes mike cheer"s. sean
In reply to M0HGY:
cheer’s jimmy looking forward to copying you and tom in GI next week i will be listening for you on 2mts best73s, sean.
Hi Sean,
I hope to work you on 2m FM if conditions are good next week.
Jimmy M0HGY
In reply to MW3PZO:
Congratulations Sean, and good luck with the uniques target!
Thank you for your assistance in spotting me on Mynydd Mawr last week (it helped me make two 12m contacts that I probably wouldn’t have managed otherwise) - I did call you at the end of the activation to say thanks, but a big black cloud was heading in, so I beat a hasty retreat!
Best 73s
Adrian
G4AZS
In reply to G4AZS:
no problem adrian i always try to help out if i can many thank’s,and best 73s sean
In reply to MW3PZO:
Well done Sean. I hope you reach your target of 1,000 uniques soon.
I often hear you on 40m.
73 de Mick M0MDA
In reply to MW3PZO:
Congrats Sean. Good Luck with the next one!
Karen
In reply to M0MDA:
cheer’s mike i often hear you pretty well on 20m best 73s sean
In reply to 2E0XYL:
thank’s karen i have had lot’s of point’s off you especialy when i’m on my hump
HNW-053 moel tryfan, speek soon best 73s, sean
In reply to MW3PZO:
I’d like to say a big thanks to YOU Sean! You have helped me qualify many GW/NW summits on VHF in the last couple of years.
Well done.
Gerald
MW0WML
In reply to MW3PZO:
Well done, Sean. I think it will be a long lime before I get there.
Thanks for all the contacts while I have been activating; looking forward to more.
Rod
In reply to MW0WML:
it’s been a pleasure gerald thank you for the point’s best 73s sean
In reply to M0JLA:
thank’s rod hope to hear you soon best 73s sean
In reply to MW3PZO:
A word of caution Sean. Check your chaser log and use the facility to display all your unconfirmed contacts. There are rather a lot of them and many of these activators have indeed entered their logs - and you’re not in them.
I reckon a bit of housekeeping is in order before you can be sure you’ve gone through the 5000 points threshold. Hope to work you from GI next week.
Tom M1EYP
In reply to M1EYP:
cheer.s tom looking forward to it,a had a good run with MI3ZCB carolyn and
MI1MAJ martin last week glad your doing the one pointer’s, till then best73s sean
In reply to MW3PZO:
…so are you going to delete the chaser logs in your account that are unconfirmed, but where the activator has entered their log? ie, you are not in the log, you were not worked by the activator!
It might mean you are not quite at 5000 points yet after all - you need to check your logs carefully.
Tom M1EYP
In reply to M1EYP:
In reply to MW3PZO:
Tom M1EYP
Tom,
Parity.
If you are going to do these checks, then do it for others, otherwise it is unpleasant to read.
Night night
Mike G6TUH
