2m Saturday DATA
Following on from my 2m data experiments - I will be activating Shining Tor (G/SP-004) this Saturday from 1100z.
I will be using both PSK31 and Olivia 16/500 modes. This will be on 144.138MHz + 1500Hz. Olivia is showing itself to be a very interesting weak signal mode in 2m tests I have conducted recently with GW0GHF in South Wales. If you have the mode it might be interesting to set your PC to the frequency - just because you can’t hear it, doesn’t mean it’s not there! :slight_smile:
Hopefully see you on the waterfall from the Tor…
Rob G7LAS
