Thanks Luc, I sorted the data to try to spot my duplicate typing and then combined where it appeared two stations were on the same summit - in this case I forgot to remove one entry. OK, down to 73 active summits - still a very good number. I will correct and re-post the table.
Thank you to Mike, 2E0YYY and Andrew, VK1AD, for this nice event!
I was at CT/ES-007, Senhora do Socorro, with CT7AGR. We decided to activate in such a way that we do not interfere one each other.
The Wx is fine (forecast was worst than we faced…): 11C, cloudy and wet.
We setup very early, before sunrise, in pitch black.
I take advantage of a flag (?) pole that is on site to erect my 20/30/40 trapped dipole.
Me and Paul, CT7AGR, we were both using KX-3’s and no other forms of PAs…10W max!
He used a endfed.
I made 29 QSOs, 9 were S2S. 1 S2S with VK2AOH/p. Another contact with VK3XU.
Both CT/VK QSOs were on the 30m band!
When we decided to leave the summit, temp had changed from 11C, wet to 22C, dry.
At that time, we were using t-shirts!
Hi ail
Thanks for your reports.
Here I was on F/PE 322 starting in the night.
After some QSO with east EU, I was called by VK5CZ and then
a difficult but valid S2S with VK2AOH/P .
Here with my FT817 5W and a ‘L’ antenna on 20m cw.
73 Alain F6ENO
