Hi Pom, I had the same impression that condx were good from DL/AM-058 today with 2 x US, 2 x UK, 1 Sweden, 1 Greece & 2 German contacts on 20m inside 10 minutes. I am also worried that the good conditions are a pre-cursor of the Solar winds hitting us. (often conditions improve for a couple of days before). I was just using a tripod mounted HF-PRO-2 vertical.
The HF-PRO-2 isnāt a dummy load (I have several verticals that could be described as dummy loads but not this one) - far from it - Iām quite impressed with it so far.
I had my 6m mast, linked dipole and OCF also with me but didnāt need to unpack them.
Hi Ed, I nipped up to my radio club this afternoon to check out the bands. Turned the beam West and worked nearly 50 North Americans on 20m ssb. Conditions were up, however, the speed the band closed was alarming.
There seemed to be a lot of QSB around yesterday as well. Weāll need to see what tomorrow brings - perhaps the solar winds will hold off long enough to make some good contacts - at least Portable EU to Chaser NA - but of course S2S would be a lot nicer!
Iāll be about 400km SW - latest weather forecast looks like high winds (and rain/snow) are coming late morning/early afternoon. As a result, Iām going to move up my schedule and activate earlier (1300Z) and probably leave the summit by 1500Z. (this is assuming weather forecast doesnāt get any worse before then)
I will focus on 20M but Iāll have 40M for local S2S/chasers. Iāll chase any 17M DX I see spotted by kicking in the KX2 ATU (antenna will be 20/40 EFHW about 30ft above the summit). I will cq only on cw, but will chase every ssb activator that is spotted if I can hear
Thatās my plan as well Barry. Freezing rain would keep me off the road and so off the summit, but anything else I should be on the air for at least some time. Rain or snow with wind will curtail on-air time though.
I hope to catch you on the air tomorrow. 73.
Thankfully we will be having better weather down south tomorrow and I will be on W4C/US-001 around 1200Z looking for EU stations. Running 45W into a 88ā doublet or 20/17m vertical.
NASAās Solar Dynamics Observatory is monitoring a large hole in the sunās atmosphere, now directly facing Earth.
A stream of solar wind escaping from the opening is expected to reach our planet during the late hours of Nov. 3rd, likely sparking minor G1-class geomagnetic storms over the weekend.
Well Iāve got my Tarp ready and my gears packed I think Iāll be on G/TW-003 but Iāll do an alert on the SOTA Alerts tommorow morning. Iāll be CW only - as usual.
I will not be activating but Iāll try to chase as many activators as possible, focusing on the NorthAmericans with my newly remote capability.
Good luck to all activators and lots of S2S.
Love Robin Hoodās Bay (Iām from Hull originally).
I take it youāre heading off to one of the TW summits then. If youāre able to come to the ādark-sideā (SSB) itād be great to get an S2S with you from DM/BM-135 Hesselberg, for which Iāll be setting off for in half an hour (itās a good 2 hours drive from here) and itās cold again and no sign of any sunshine yet. It always seems to be cold and cloudy or foggy when I go to Hesselberg - I havenāt seen the views from there yet.
OK, hereās my last snapshot of those taking part today, as Iām about to set off on my drive to my chosen summit. Iām very happy to see how many will be out - I suspect the 9A may be a bit early for any NA contacts but good luck to him and heāll no doubt get lots of EU chasers in any case:
OK some may not be out for the S2S event, but theyāre out there - so good luck to everyone.
(sorry about my double entry - I canāt delete either of them - to clarify Iāll be starting between 1300 and 1330 UTC for 1 to 1.5 hours, mainly concentrating on 20m but 40m as a fallback).
P.S. the sun just came out here - yea - that has to be a good omen - right?
