Summits near Cardiff?
Morning All
A works activation opportunity has just presented it’s self. I will be working in Cardiff most of next week. Can anybody suggest a couple of near by after work summits/hotels/Indian restaurants etc to keep me occupied please?
Thanks
Tim
G4YTD
In reply to G4YTD:
Hi Tim
The only one I know, not being from the area, is Wentwood GW/SW-033. It’s easy to get to (M4 to J24, A48 towards Chepstow, then minor road from Parc Seymour), not too strenuous for an after-work summit, and not activated too often. Can’t help with the restaurants though …
73 de Les, G3VQO
In reply to G4YTD:
I can’t help with the infrastructure of Cardiff, Tim, but SW-034 and 037 are just outside the city by a few miles and SW-024, 025, 027 and 030 are all less than 10 miles from the edge of the city. Another half hour or so up the A470 would bring you to SW-001!
Thanks Brian and Les
Packing the car now ready to go!
I have bought a couple of maps and will mark them up with the summits at the Hotel tonight. Weather permitting I should be able to grab a few points over the next couple of days.
Thanks for the info.
Tim
In reply to G4YTD:
You might want to consider buying something like Memory Map or Anquet. I got a price match deal on Anquet and paid about £120 for complete 1:50000 coverage of the UK. I’d hate to think how much it would cost to buy all 204 OS Maps and I haven’t got a shelf big enough for them either. I simply print out the section I need at 1:25000 scale and stuff it in the mapcase. At 1:25000 scale I don’t need to wear glasses to read the text!
You can also download overlay markers for Anquet (and I assume MM) which mark all the UK Marilyns. Overays exists for all the mountain sets ( e.g. Munros, Corbetts, Grahams, Donalds, Elsies, Alberts, Majories, Nathanials and Uncle Tom Cobbleys!).
I’ve had my money’s worth and I’d recommend either of these programs for anyone slightly serious about SOTA activations.
The Marilyn overlays sounds useful
Where do you get the overlays for Anquet and how do you install them?
I’ve managed to find a a likely looking .gpx file but have no idea how
to import/install it.
Any help appreciated.
Rick.
In reply to M0RCP:
I can’t remember right now. Possibly the Harrold Street website but I’m sure a bit of googling would help. ISTR I downloaded them as *.aef files and told Anquet about the directory I’d downloaded them to. If I can’t find the source website then all is not lost as they were freely available so you can always have a copy of my files.
I forgot to check last night but I’ve got a big compile running so I’ve got over hour while the PC chugs away. After a moment Googling I found this…
http://www.haroldstreet.org.uk/waypoints/download/?list=marilyns
I downloaded AEF files (Anquet export format) and if I remember correctly I went to the import/export option and imported the AEF files. After a bit of think, Anquet showed a red blob on all summits which are Marilyns. You need to have the magnification set to no less than 75% to see them though.
Many thanks for the help Andy. The following procedure seems to work:
  1. Download and copy the file to the Anquet Maps Databases directory
  2. Navigate the Anquet menu: File > Database > Open
  3. Select *.aef file-type filter
  4. Select the appropriate file
Net result: red way-point markers appear at the appropriate locations (though I notice NW-001 is a little off its correct position). The above procedure also works for GPX files (I checked it). The only problem is that the SOTA references are not present - the names are - if you scroll far enough over to the right of the database explorer window.
My next question is thus: does anyone have a .gpx (or .aef) database containing the SOTA summits together with their SOTA refs and names? Perhaps such a file could be created automatically from the database or by converting the existing Google earth .kml files.
Even without the SOTA refs having the SOTA summits marked is a great help for expedition planning.
Thanks again Andy and 73
Rick.
