On SW1 a small c in red used to appear on the left hand side when viewing the summit lists. This showed if you had worked the summit or not. It doesn’t appear to do it on SW2, any chance this feature could be added?
Mike
Mike
In reply to GW0DSP:
The feature is there. It looks slightly different, but is more detailed. Now, when you bring up a list of summits in a region, there are columns over to the right hand side that tell you not merely if you have activated/chased a summit, but how many times.
If this is not appearing, then perhaps you haven’t logged in.
73, Tom
In reply to M1EYP:
OOPS!!! Doh, egg on my face Tom. I see that when you use the link in Sotawatch, you still have to log in seperately to the database.
I have just logged in and there it is.
Thanks for your help.
73 de Mike
