SOTAwatch Outages Today
Hi,
My sincere apologies for any inconvenience caused by the outages of SOTAwatch during today.
I have needed to move the system to another server and it didn’t go quite as smoothly as I had anticipated. I had hoped for it to be seamless and unnoticed!
However, I think we are there. Please let me know of any further problems.
73, Jon
In reply to GM4ZFZ:
H Jon
The links to summit info doesn’t seem to working from spots and alerts.
Clicking on link just gives blank page.
Roger G4OWG
In reply to G4OWG:
Thanks Roger, I had spotted this after I posted and am currently working on a solution.
Thanks and for sorry for the inconvenience.
73, Jon
In reply to G4OWG:
OK, got that one nailed. Let me know of any other problems.
73, Jon
In reply to GM4ZFZ:
Minor one Jon.
Apostrophe in post is coming out as \\\\apostrophe eg this It\\\'s (typed correctly). And I only typed one slash :slight_smile:
Roger G4OWG
In reply to G4OWG:
Whoops it is catching see Martyn maj post :frowning:
Roger
In reply to G4OWG:
I have just mailed Jon about this. It got worse because I tried to fix it with “Edit” :frowning:
In reply to GM4ZFZ:
Hi Jon,
I have been trying most of the day to post a reflector Thread Report, It has just accepted it but I cant see it when I click to open it?,Although when I hover my mouse over subject I can see it in the review pane???
Tony
In reply to GM4ZFZ:
Sorry Jon all working now Thanks
Tony
#10
In reply to 2E0LAE:
OK, I think I have solved the apostrope/slashes problem.
Let me know of any further issues that you see.
73, Jon
#11
In reply to GM4ZFZ:
I still cannot edit out the backslashes in my posting. I have been able to get it down to one backslash per apostrophe, which is an improvement.
#12
In reply to GM4ZFZ:
If I mouse-over G6SFP`s message re f/ab-295 Pointe de Lapaz, I can read it. But if I double click to open it, the message is missing.
Cancel the above - its ok now, maybe just a delay in the works.
#13
In reply to G1INK:
I’ve just posted a new thread about radio gear and airports and all the single and double quotes are preceeded by one backslash.
#14
My reply to Andy’s aforementioned post appears to be OK, unless I’ve missed something?
Mark
G0VOF
#15
In reply to G0VOF:
Figured it out. If you just enter a message then single and double quotes work fine. If you run the message the spell check option then the single backslash appears in front of the quote characters.
#16
In reply to GM4ZFZ:
Hi Jon
The Daily Digest of messages that I get from the SOTA Reflector has ceased since we went over to the new server. Do I need to do anything at my end or do you need to configure something at the server end Jon?
Many Thanks
Phil
#17
In reply to G4OBK:
In reply to GM4ZFZ:
Sorry about this Phil, I hope to get this re-instated during today.
73, Jon
#18
I can’t seem to “repli"icate” this one Andy, could you tell me exactly how to see it? I’ve tried running the spell check.
73, Jon
#19
In reply to GM4ZFZ:
test: not using spell check
a’b c’d e’f
#20
test: using spell check
a\'b c\'d e\'f
a b c d
