SOTAWatch Alerts summit recognition problem - FIXED
It appears that SOTAWatch doesn’t recognise recently added summits - one example is DM/BW-854 Höchsten. Is it possible some kind of transfer or update needs to be executed to get new summits recognised in SOTAWatch Alerts?
Tnx Ed DD5LP
Hi Ed,
I brought up this topic some months ago. Here is the thread:
73 Martin, OE5REO
Working FB
Alert placed 1730Z 9/2/2018
c1
Spot placed 1728Z 9/2/2018
c2
And…
c1
c2
Those alerts are not there Andy!
I guess you removed them?
In any case what I am referring to (I ought to have been clearer!) is that when one hovers the mouse over the entry it says summit not recognised - the system allows the alert to be placed, that’s not the problem.
By the way as I wrote DD5LP+Others I’d expect the Operator not to be recognised - it’s just the Summit where I would expect to see the name shown.
Ed.
Recently updated E7 SOTA data does appear in the list of summits, sotadata-generated pages, and SMP maps, but not in the Alerts page (when one hovers over an E7 SOTA reference). I believe this peculiarity has the same root cause as the one Ed is referring to…
73’s!
Zoran / E70AA
Jon has an update planned soon.
Thanks.
SOTAWatch Alerts continues to report any summits added in 2018 (and I think also late in 2017) as unrecognised.
I know there is a “bigger plan” to replace the current SOTAWatch with a better one but in the meantime, can the problem be addressed in the current system please?
#10
Posts like this are better sent directly to the MT, I’m the only member of the MT more or less continually monitoring the reflector and I don’t deal with the nuts and bolts!:wink:
#11
It was my understanding that you had to deal with the nuts and then bolt. Perhaps I got that wrong…
#12
That sounds about right to me!
#13
OK, I’ll send something to Jon to see if the update that Andrew R said he thought was coming is imminent. I know this problem used to occur when a particular lookup file wasn’t updated but then this manual step of the logic was apparently changed to take the data directly from the database - that doesn’t seem to be working for the new summits in the Alert page (Spots seem to be OK).
#14
It’s dependent on another piece of work I’m working on (when I get a chance).
#15
Thanks Andrew - I’m in direct contact with Jon now via email and he’ll kindly look into the problem later when he gets home.
#16
Jon has now fixed the problem so new alerts or those edited by the creator will now pick up the name of the summit if it is valid.
Ed.
