Should RBN Hole be updating QRG if chasers qsy's 3.7KHz?
Below are RBN spots for NK6A. RBNHole correctly spotted him initially on 14.0662 at 1826Z but failed to update his QRG to 14.0625. Finally at 1832Z, NS7P manually posted the updated QRG.
WZ7I NK6A 14062.5 CW CQ [LoTW] 8 dB 25 wpm 1830z 16 Mar
K8ND NK6A 14062.5 CW CQ [LoTW] 2 dB 25 wpm 1830z 16 Mar
VE7AB NK6A 14062.5 CW CQ [LoTW] 4 dB 25 wpm 1828z 16 Mar
W3DX NK6A 14066.2 CW CQ [LoTW] 5 dB 25 wpm 1826z 16 Mar
73, Barry N1EU
It should. I will check and see what needs adjusting.
Have these, they may help.
I recognise the one on the left as the famed and versatile Edinburgh socket set :smile:
The one on the right I believe is used for social engineering
(xkcd: Security)
Just fixed one bug on alerting times - sorry K1JD! My window was offset by 2 hours by mistake comparing against the wrong variable.
Humans 1 computers 0
RBN Hole again needing a nudge. W4EON received the following RBN spots today:
KM3T W4EON 10118.0 CW CQ [LoTW] 17 dB 15 wpm 1725z 26 Mar
WE9V W4EON 10118.0 CW CQ [LoTW] 15 dB 15 wpm 1725z 26 Mar
AC0C W4EON 10118.0 CW CQ [LoTW] 17 dB 15 wpm 1725z 26 Mar
KC0VKN W4EON 10118.0 CW CQ [LoTW] 24 dB 15 wpm 1725z 26 Mar
AC0C W4EON 10094.0 CW CQ [LoTW] 4 dB 15 wpm 1724z 26 Mar
But he got only the single (wrong) spot from RBNHole:
Sat 17:24 W4EON on W4V/HB-033 10.094 cw
*[RBNHole] at AC0C 15 WPM 04dB SNR (Posted by RBNHOLE)
