Can someone quickly refresh my memory of the format for a SMS spot? I tried it from Bishop Wilton Wold last week but couldnt remember the format! I’ll set a template up on my phone
Martin
Martin
In reply to G7MRV:
Everything you need is here -
http://www.intermoose.com/SMSBOT-usage.txt
73 de Les, G3VQO
In reply to G3VQO:
Thanks Les, you beat me to it.
Martin if you have a phone running Symbian S60 3rd edition or higher you can have a copy of the program that makes entering spots trivial.
Here is your log entry:
Thu Jun 16 11:32:16 2011: +CMGL: 1,“REC UNREAD”,"+44xxxxxxxxx","",“11/06/16,11:
31:30+04”,G7mrv g/tw-004 145.5
Thu Jun 16 11:32:16 2011: Bad format: only 3 fields in message
Turn around time from you hitting send on your phone to me processing the spot was 46 seconds. FYI you can use ! for your call and you need to split the reference into its country and summit parts. You don’t need the -, I’ll insert that if it’s not there.
i.e. ! g tw004 145.5
Many thanks fellas
I can see what i did wrong now! I’ll set a template up for next time. I dont use a smartphone, just an old thing im afraid.
Cheers
Martin G7MRV
In reply to G3VQO:
Hi,
being relatively new to SOTA can anyone tell me how do you register for the gateway for sending an SMS spot?
Thanks
Colwyn
MM6YCJ
In reply to MM6YCJ:Hi Colwyn
Contact Andy MM0FMF.And he will sort you out ATB Geoff G6MZX
In reply to G6MZX:
…and how do you contact Andy?
In reply to G1STQ:
Leave a message on here with your email address and ask him to contact you.It would not be fair for me to publish it.Thanks Geoff
You take a look at
http://www.sota.org.uk/AboutSOTA
which contains a brief Bio and contact info for all the SOTA management team
Colin G8TMV
In reply to G8TMV:
Thanks.
In reply to G3VQO:
Hello,
Thanks for the information. But I don’t found where I have to register bevor using the gateway?
Best 73 de Laurent, F8CZI
Andy MM0FMF’s email address is on the GM (Scotland) ARM.
Jimmy M3EYP
