The World-Wide CQ RTTY Contest continues until midnight tonight, effectively swamping out 40m from 7.025 -7.065 MHZ with high power stations, making it just about impossible to hear SOTA activations.
Can I suggest that the activations alerted for 7.032 MHz today follow Klaus’s example and try calling about 10 KHz down (7.020 +/-). There is also an EA CW contest but at least you will have a chance of being heard outside the RTTY transmissions.
In reply to G4SSH:
good idea Roy! yesterday, it was the chaos with this contest, a poor day for the sota! for my side poor propagation, QRN and contest outside of bands!!
hope to hearth some sota station today!
73’s for all
f5nep
lionel
It looks like another day of disorganised chaos, I just heard DL6WT/P and DL6UNF/P, but despite several attempts to make the contacts with them, I wasn’t being heard amongst the chronic QRM from RTTY and cw contests. I heard Frank suggest a qsy to 7.025, but never heard him again.
The obvious choice under such conditions has to be a QSY to 30m
73 Mike GW0DSP
P.S. First station to use 10.118, OE5EEP/5 was just worked with ease in a QRM free environment, we really need to consider this band more often.
What a racket on hf with rtty stations just working where ever they
want in the band so decided to turn the radio off and mow the lawn
instead
a real poor day for the sota activators who are trying to make contact
so much for bandplans hi hi
GORDON MM3XGP
I very nearly did the same myself Gordon, but I need the points so I played with the filters on the IC-7400, end result 100 chaser points and 9 uniques at the time of printing this.
Hi roy ,
thanks qso´s today . you wrote 30m free of contests, but also often free of chasers,hi.
in future i will be more qrv on 30m-cw and 80m-cw. mostly on 30m not so big signals as on 40m , but on 30m you can work signals with s3 - s1 due to the low qrm. on around 10118 you can work with the big plus of cw-mode and make qso´s only a few db´s over the groundnoise.on many on my activations i work HB9AGH there with abt. rst 339-319 ( maybe direct ? )
also a new regular band over the autum/winter months is 80m / 3558-cw for me with very good signals today on DM/BW-007. Many chasers called me there and it seems a very good band for my friends from HB9 . Also workes there sum G´s today . And all today with a output from 3 to 6 watts due to not ok trx. antenna today 2 times 26m doublet inv.V. 4m over ground.
also a new regular qrg is 40m SSB with many chasers there. thanks ssb guys for qso´s today.
and in the future contest times, try 30m ! and cw on >7100 with ssb and cw on same qrg. so i think we can do sota also in contest times
vy 73 Klaus DF2gn
now looking over my trx to find the fault in the output-filter/pa-stage
/edit : after 30min , hi. trx seems ok at home antenna with 12 and 13,8v.
mmhhhh, murphy greets…lets have a look tmrw on antenna and tuner.
someone heard a little of HF on my ssb-mod ?? or was ssb-mod ok ?? maybe some problems with lower counterpoise on portable setup…
For QRP work the frequency is critical. Optimum depends on distance, azimuth, season, UTC and space weather. For inside country QSOs 80 m is probably best, for general European QSOs 40 - 30 m, and “DX” to Scandinavia/Portugal/Greek 20 - 17 m. I tried to estimate these with VOACAP, see for example
