Problems posting to reflector
Hi, just trying to add a post to a thread on the reflector and I get the following message:
“We had a problem inserting the post into the database”
Funnily I had no problem posting this message to a new thread
Rick
In reply to M0RCP:
See if you have any apostrophes, if so remove them and try again.
In reply to G8ADD:
Ah! Thanks Brian. I vaguely remember something about this.
73 Rick M0RCP
In reply to G8ADD:
This is definitely discriminating against any grocer`s using the system!
:slight_smile:
If its Grocer Jack I will discriminate with enthusiasm!
In reply to G8ADD:
Could the error message not be changed to something like
“Your post has been rejected because it contains an apostophe”?
Rick
In reply to M0RCP:
No.
The error message will be replaced by fixing the problem. That will happen when the man who provides it all for free has a moment to sort it.
No error message here - just no posts. Will have to try again.
73, Gerald G4OIG
In reply to G8ADD:
Perhaps the ability to post with apostrophes could be made a Premium Feature to raise funds?
Richard
G3CWI
In reply to G4OIG:
Its easy to miss: in small print just above the Sotawatch 2 heading.
In reply to G8ADD:
No error message came up at any time here Brian. My posts just got swallowed up. Maybe FireFox blanked the response. Still, it is not a problem now we know how to circumvent the issue. At least we can still post smileys :slight_smile:
73, Gerald G4OIG
As a workaround you can utilise the inverted comma on the key to the left of number 1 on UK keyboards rather than the apostrophe bellow the @ sign on the right hand side of the keyboard.
Thus - Connah`s Quay
Steve GW7AAV
Just a ‘note’ to say that the standard keyboard apostrophe’s in post’s DO work and WILL be accepted by the reflector - if you know’s how :wink:
Have fun!
Rob DM1CM
In reply to DM1CM:
Thanks for the ‘tip’ Rob
73 Rick
