Problem logging chaser contacts
I tried logging some chaser points this morning, and was greeted with a BIG red error message. This is a small section of it…
An error has occured whilst saving the Chaser Details :
System.ApplicationException: Database Error Adding Chaser Entry —> System.Data.SqlClient.SqlException: The transaction log for database ‘sotadata_db’ is full.
Full ?? maybe I had better not work as many summits :smiley:
73, M0MOL (Gareth)
In reply to M0MOL:
I have had this problem all i did was completley log out of the reflector site then log back in again hope this helps Dave M3XIE
In reply to M3XIE-1:
Just tried that, and it didn’t work :(… The reflector seems fine, its just the database that doesn’t let me log contacts.
In reply to G4OOE:
I have the same problem. I have tried logging out and in again but
still no joy.
Nick G4OOE
In reply to G4ZIB:
The log is full on the server. It will be sorted ASAP. In the meantime the database adding activations and chases is not possible.
Thanks to some fancy finger work by Gary G0HJQ the database should now be working.
Seems OK.
Stewart G0LGS
In reply to G0LGS:
Sorted now, Cheers :smiley:
