Is anyone else getting this error?
Sorry if this is a repeat, I looked around and checked FB page first, also with different browsers over a couple of hours.
Yep, just got it for ZL, no doubt they will fix it.
Has now been reported to ops. They can only fix it if they know about it.
Adding extra information - this seems to ONLY affect certain associations - the ZL1 region is one example, whereas DL works fine.
Looks like a connection problem to the db? Or a broken lookup query? Or string formating?
On the activation page entries are shown as NULL
See screenshoot:
(FYI: Sotadata - and newsotadata - are working fine)
73 Joe
There’s a problem fetching data from the main SOTA database into the DB that the SMP uses. I’m looking into it, but it appears to be either a slow or intermittent connection.
…and we should be back.
Thanks Andrew!
Activation view on Sotamaps works fine.
