In reply to M0TUB:
In reply to 2E0YYY:
Quote
"At the moment,the FT-817 is a Golf GTi powered by an Austin
Allegro engineCue the Morse Evangelists "
Heathen
That’s not the spin you put on the one you sold me!!
LOL…
73 Mickey
In reply to M0TUB:
In reply to 2E0YYY:
Quote
Heathen
LOL…
73 Mickey
In reply to 2E0YYY:
In reply to G8ADD:
Hi Brian,
Having owned about 5 or 6 of these on and off, The biggest improvement
to this rig would be to up the available power from 5 to 10 Watts.
Doubling the power would get you half an S-point. A built-in speech compressor would have more effect!
In reply to G8ADD:
Or a better aerial. Or even AM!
If it was 20-30W it would probably be noticeable. I’ve had a plenty of contacts on 60m using 0.5W and still received good reports. Brian G4ZRP has worked Phil G4OBK on many SOTA/WOTA LD summits using just 16mW (milliwatts) of 2m FM.
Andy, MM0FMF
(Only QRO when it really makes a difference.)
Every watt of output power has to be carried up to the summit as weight in the form of the battery. Then again I suppose Mike could dispense with the patio heater from his backpack to make room for the additional SLABs, especially as it is now summer. LOL.
As for more power output from an FT-817, that would probably be more useful on HF than VHF/UHF. A small HF linear would probably be a better option than raising the power of the 817.
73, Gerald G4OIG
But the overiding reason is the faux-kudos you can garner by saying you have an
Elecraft radio rather than something everyone else has! The radio is good ergo
I am good because I have bought one.
Yes, I suspected that was the principal reason!
The FT-817 and the FT-857 will do me fine for many years yet.
I usually keep and continue to use a transceiver for 15 - 20 years. I have had my present main station radio (TS-690S) for 19 years and I see no reason to change it. For 2 metres multi-mode, the FT-221R which I bought in 1975 still works perfectly well.
Walt (G3NYY)
In reply to 2W0CYM:
Another fantastic April fools I think!! One for the CW lot out there!
It wont Hyperlink for some reason, please copy and paste!
Matt G8XYJ
In reply to G8XYJ:
No, it’s a rubbish April Fool just like all the others.
In reply to G4OIG:
Tried out my new bad boy, 22Ah ultra deep cycle golf cart SLAB on G/SP-013 Gun, yesterday. Weight wise, it’s manageable, although I think attemting a 10 pointer may need some serious consideration
Ah, I dispensed with the patio heater last year, Gerald and replaced it with a brasier (which doubles up as a BBQ) and chainsaw for harvesting some fuel… Burger anyone
73 Mike
2E0YYY
In reply to 2E0YYY:
Ah, some way to go then to my antics of carrying a 34AH car battery… up Kinder Scout from Edale! That was for one of the 10GHz contests back in the early 80’s when we ran wideband FM. I also went up a hill near Llangollen to achieve the RSGB 10GHz 150km distance award with the same kit… and it rained all day!
I can suggest a few single point SOTA hills that would make you think twice as well!
No doubt you want us to bring our own bread rolls to save weight…
73, Gerald G4OIG
In reply to G4OIG:
Anyone who takes a car battery up Kinder, deserves a medal IMHO.
I took a 12AH SLAB and FT-857 up there last year and that was hard work.
pointer may need some serious considerationI can suggest a few single point SOTA hills that would make you think
twice as well!
Yes, I know there are some very tough 1 pointers
harvesting some fuel… Burger anyoneNo doubt you want us to bring our own bread rolls to save weight…
If you wouldn’t mind too much Gerald, then you can quickly warm them up in the microwave oven
73 Mike
2E0YYY
In reply to 2E0YYY:
Frivolities! Who is going to carry the cask of real ale?
In reply to 2E0YYY:
What about if you carry it up a proper hill like The Cheviot?
http://www.flickr.com/photos/mm0fmf/3996939015/
http://www.flickr.com/photos/mm0fmf/3996949259/
Yes the climb up is rather steep, to say the least.
I see you went in summer…
http://www.flickr.com/photos/18897403@N00/458067215/in/photostream
http://www.flickr.com/photos/18897403@N00/458067245/in/photostream
In reply to G8ADD:
That’s a serious question Brian. I assume that you are not volunteering.
73, Gerald G4OIG
In reply to G4OIG:
Yes it was a lovely summer’s day as I recall. I only need two layers of fleece, a GoreTex jacket and the double layer Alpaca wool hat. Brian, always concerned, applied two layers of factor 30 sun creme, just in case!
Today’s snow/blizzards have now stopped and most of it has melted. Just the odd white patch higher up.
In reply to G8ADD:
In reply to 2E0YYY:
An extremley well chilled bottle of vintage Bollinger for me, Brian.
Followed by a bottle of Chateauneuf-du-Pape, as an accompaniment to the burgers…
Failing that, I’ll settle for a can of Bud
73 Mike
2E0YYY
