The old version will continue to work for the time being but will be discontinued at some point in the future.
The new version, by request, has a couple of new features:
the ability to add alerts
a ‘Get URL’ button to make it easier to save spots/alerts as favourites on your phone.
It’s a little rough around the edges and does need some more work so please do let me have any feedback and suggestions and I will try and improve it over time.
as an address for general monitoring (to find out who else is QRV for potential S2S contacts) and all I get is a message: “Sorry”. Can you shed any light on this?
with DL4MFM/P it doesn’t work
Maybe because the slash is the separator?
Yes, correct. Obviously slashes mean something else in URLs! This is what I mean about it being a bit ‘rough around the edges’! I suspect at somepoint I’ll be able to figure out a way of getting around this.
So, for now, no slashes. Sorry!
73, Jon
P.S. I suppose by definition an activator is always /P so perhaps I should ‘hard code’ it?
However, I have also added http://www.sotawatch.org
To be honest, I have no idea what is happening here. Stumped!
However, you can get a both a simple list of spots and alerts with the following URLs:
In reply to LX1NO:
Don’t forget that there are some countries where it is required to show the callarea of a portable operation. I think this applies in Hungary and if I am not mistaken, Austria. They sign OE5xxx/4 if they operate portable from the Austrian callarea 4 etc. in place of the customary /P.
Could some of our SOTA friends from OE and / or HA confirm or otherwise?
73 de Ken
Thanks John, just what I wanted! It’s mainly to check on progress with other activations that may provide S2S contacts. Mind you, I often get told who is on and where by Chasers.
OK, thanks very much - being thick here - we really do need slashes.
I have modified the code to replace slashes “/” with dots (fullstops, periods) “.” in the URL. I chose this because it would be easier to find on a mobile phone than a hyphen (at least it is on mine).
So if you create the URL yourself, use a dot in place of a slash. The ‘Get URL’ button does it automatically.
Alain, regarding spaces: The spaces in the comments field will be replaced by “%20”. This is perfectly normal and is how the URL handles spaces.
