http://qrznow.com/new-kenwood-tribander-144220440-mhz/
Think this is the new Kenwood radio.
Kenwood made a preliminary announcement -
Dual band HT with GPS - FM/APRS/D-Star - USB and SD-Card. No release date or price as far as I have seen so far.
SSB receive. I’m not sure the spec implies SSB TX.
Agreed - I’m trying to find out more, I’ll update one way or the other.
It would be different for a HT to have SSB nowadays, but if it’s SDR based, definitely a possibility - we’ll have to take a closer look at Friedrichshafen
Ed.
UPDATE: OK, now I’ve found the info. The HT is a tri-bander 2m, 220MHz, 70cm running FM and supporting APRS and D-Star. Also within the rig is a wideband receiver, which can receive HF/VHF AM, FM, SSB & CW. Similar to what the Yaesu VX range does I believe.
Nice to see I would not be the only one missing 2m/70cm allmode in a FT-817 successor. Agreed besides contests 2m SSB and especially 70cm SSB are nearly empty. But there is a contest nearly every 1st weekend of the month in Germany. Especially 2m/70cm takes most use of a good location, so the ideal time to get up a mountain either in combination but also besides SOTA. Receiving “big signal” from a >1 kW contest station with a Yagi group while running the FT-817 on 5W with and a HB9CV from a high summit is always great fun. Having a rig without 2m SSB simply is no option for this use.
These are exactly the systems which detract you from traffic during use: You cannot use them without looking at some kind of display as you always have to check which variable is controlled by the knob currently. All functions (more or less) essential for driving are still dedicated buttons/knobs: blinker, light, wipers, gear stick/selector for manual transmission, engine start/stop and not to forget the most vital controls steering wheel, brake, accelerator and clutch for manual transmission. I just think about a single-dial concept for brake and accelerator
Btw: Even the BMW iDrive as a typical single-knob-solution has dedicated buttons for CD, RADIO, TEL, NAV, … .
Soft keys and an universal knob are good for parameters you only change occasionaly. But for volume, frequency, squelch (at least momentarily switching it off), notch filter, passband / IF shift, tuner I prefer individual controls I can use without watching some display. The FT-817 fails regarding a few of these but nothing is perfect.
Facing bright sunlight, darkness, rain, snow, a poor rig position and many other typical outdoor situations make reading any display a hassle.
@DD5LP
To my mind successor rigs do exist. Especially for the FT-817 I can imagine one. The FT-817 seems to be selling well even today. No wonder, as it is the only model in this special segment of market. This is also the reason a 15 year old rig is not withdrawn by Yaesu. But once Yaesu cannot get the components (RF transistors, whatever) anymore they will not upgrade a 15 year old design but present a newly designed successor.
I can even imagine there will be a run on the last FT-817 units. Even if the successor will have all features of the FT-817 and even fix some of the FT-817 drawbacks (outdated internal power supply, poor DSP without notch filter, quite poor intermod) there will be one drawback of the successor: Price. A new design has to pay off for Yaesu so they will not start with 500 - 600 € retail price.
I fear the new Kenwood HT will only receive SSB and not transmit. That’s a common feature also for older Kenwood HTs. The description clearly says “multi mode reception” and “IF filter for comfortable reception (SSB/CW)”.
73 de Michael, DB7MM
If the ft791 doesn’t have UHF/vhd and HF ssb capabilities I’ll be one of those buying up an ft817 before they sellout. They are currently only £435 online new.
I can only find Razvan’s blog mentioning the possible FT-791 rig - there doesn’t ssem to be anything announced at Dayton about an FT-817 replacement, so this does appear to just be a rumour at the moment. While the other new Yaesu rigs seem to be replacments for the FT-857 and 897 (even if at the moment Yaesu say they aren’t), there’s no reason to presume that if two of the FT-8x7 rigs are replaced, the third one will be as well - or do you know more than you say in your blog Razvan?
Ed.
Two metre upgrade module for IC-7300.
This from the IC-7300 Yahoogroup from Pete G4BLF:
Optional 2m module for the 7300 only just came out and is still in short supply.
I’m not surprised it’s in short supply - the IC-7300 itself is in short supply!
Don’t try ordering the module yet however, as this could have been a joke, I’m investigating.
Ed.
Update: Pete G4BLF has just posted the following:
2m module for the 7300 (which, just to be clear, definitely was a joke - or at least was meant to be because AFAIK it doesn’t exist!).
I do have some other bits and pieces of info, but between what Yaesu is researching/planning and what makes it to the public eventually there always are some differences. Take the FT-410 for example, it’s been ready for a year but it never came out (or maybe it will never will).
Anyway, I’ve updated the blog post with some more news about the FT-891, it’s the smallest and lightest 100W HF radio ever built, only 1.9kg and 15mm shorter than the FT-857. Unfortunately, it takes 2A on RX, so not really a backpacker’s dream.
http://www.qrpblog.com/2016/05/yaesu-ft-891-update.html
Cheers,
Razvan.
Who is still complaining about the FT-817 power consumption on RX ?
Well, the FT-891 seems to be built for car based operation as the FT-857 was originally. This also explains the 100 W of HF power output.
Going back to this, I notice from the database that we now list just short of 5,000 activators and are adding new activators at a rate of about fifty per month. SOTA is becoming a significant market sector and in my opinion it would be pretty remarkable if the major manufacturers were not starting to take the SOTA market into consideration when designing small rigs. It seems that Elecraft has taken this on board and as SOTA is developing in the Far East I would guess that the big three will be taking notice, too. It isn’t difficult for them to access the database and work out what our needs are!
Brian
The Elecraft designers did some SOTA field testing with the KX3. One of the KX3 field testers was WG0AT.
http://k0jqz.blogspot.com/2016/05/elecraft-kx2-on-sota-summit.html
The Elecraft founders have named two radios after mountains, the Sierra and the K2. SOTA was not a new thing for them.
http://udel.edu/~mm/ham/elecraft/history/
wunder
I think you mean KX2
