Have a look at the spot of G0PZO/P by G0RQL at 15:48 today (20/2/07). The mouseover pop-up (is that the right description?) does not pop up details of the summit/operator. The subsequent spots by GW0VMZ are OK and there is nothing obviously wrong with the spot by G0RQL.
Found a very slight glitch! On the mouseover, where it tells you how many points the summit is worth, it doesn’t drop the ‘s’ for 1-point; ie it says “1 points”.
I now note that it seems to know who me and Jimmy are, when tested on our alerts for July. Last week it didn’t know us - “operator not registered”.
If the callsign begins with a ‘G’, ‘M’ or ‘2’ I chop off the characters preceding the numeral and match the numeral+remaining characters. This is to cope with roaming UK callsigns (i.e. a G activating as a GM, etc.).
Unfortunately, if no numeral is found then the operation fails and searches the database on a blank string thus returning all users. The most recent subscriber to SOTAwatch at that point happened to be called Richard!
Well spotted! Now fixed. I have re-submitted DL2HSC/P’s alert and spot to test. New 1 point alerts and spots submitted will omit the ‘s’! Existing ones will stay as they are since I compile the ‘pop up’ summit details at the time of submission not display.
