Lightweight HF Aerials
Having realised that a radio powered by a PP3 is quite adequate for reliable activating, I am now looking at further weight reduction opportunities. Just how light can a viable HF antenna be made - and what materials were used? Just for starters, my lightest HF antenna is a longwire for 40m which, complete with radials and a back guy for the mast, weighs in at 300g. I suspect that I could use thinner wire to save weight. Ideas?
Richard
G3CWI
In reply to G3CWI:
Hi Richard
Split-down IDC ribbon cable is certainly the strongest yet lightest material I have found and works very well (a la Norcal Doublet).
73 de Paul G4MD
PS did Santa not bring you a new PP3? :wink:
Hi Richard. Good going with the PP3 challenge!
I have been using a dipole made from split ribbon cable for a few years now and it’s amazingly strong and light. The whole 30m/40m/60m dipole and feeder all fits on one ‘wire winder’ too.
Ian
In reply to G3CWI:
A half wave end fed made of enamelled wire. The tuner can be made very small and light with a polyvaricon. For normal use this still requires a fishing pole but perhaps if you aim for NVIS on 60m a walking pole in the centre of an inverted V would work.
In reply to G3CWI:
Single band EFHW matcher with 1m RG174 coax and male BNC termination- 45g
#22 wire, Teflon insulated, stranded- 4.7g/m
That would make a 20m monobander approx. 100g with feedline and counterpoise.
A deluxe multiband EFHW tuner with SWR bridge and 1m feedline- 110g approx.
Not included is rigging, which can be as weighty as a spool of sewing thread.
Stu
In reply to G3CWI:
Perhaps you could use several strands of very thin enamelled wire in a loose plait. I think this should be electrically and mechanically superior to a single fatter wire.
Also you could vary the diameter of the wire over its length, using thicker wire only where the current distribution is highest. e.g. I use thicker wires at the centre of my linked dipole and thinner wires at the end.
I also wonder whether thin aluminium tape could be used as an alternative to normal wire.
Regards,
Nigel. G6SFP.
In reply to G3CWI:
Hi Richard,
I am using TW 65 from Titanex (http://titanex.de).
info from the Titanex-website:
TW 65
TITANEX® Wire, 0,65mm ø, stainless steel with weaved-in aluminum wires, highly conductive, non-corroding, best HF characteristics, tensile strength: 30kp, weight: 110g/100m, outstanding for all wire antennas
Volker, DK2MT
