Use the SOTA cluster which is supported by most logging software. You can click on spots in your logging program’s cluster window to get the log entry pre-filled. And if you do the whole job, get the radio mode and frequency set and the antenna rotated to the SOTA station for a single click.
SOTA cluster : elgur.dtdns.net : 7300 (It’s not a webpage !)
HRD is the one logging program that I know doesn’t work!
I know there are Mac and Windows programs that work fine. I don’t use any of them, so someone else will have to suggest what they use. Also you should note it’s not a full cluster. It just presents SOTA spots from SOTAwatch in the same format as a cluster does so that you can use it with (some) logging / control programs.
I use Logger 32 and its free, other programs (some paid for) are available. As ON4UP says, Log4OM is popular also - I haven’t tried it having used Logger32 for longer than I can remember. It works for me.
I can thoroughly recommend the SOTA Cluster as previously mentioned which is kindly run by Andy MM0FMF MT member. I connect via telnet within Logger 32, just like telnetting into a DX Cluster which I have done for over 20 years - but this cluster is more relevant to my interests nowadays.
Good luck with fiddling about with the software Kent!
Logger 32 Spots window - click the spot and call goes into logbook field and transceiver goes to specific frequency. You then have to work the station of course! :
Don’t forget Kent, that much of the software on Christophe’s web site runs in a browser so you don’t need to install anything extra. And, Christophe also maintains a large list of SOTA software and websites.
Log4OM also generates the file for SOTA database upload and merges the SOTA Database download files automatically
In addition to auto filling the other stations look up information and the SOTA association, region, reference and summit name when using the SOTA cluster, Log4OM derives the correct grid square (Maidenhead locator) for the summits location.
Furthermore clicking a summit name in Log4OM opens the SOTA Mapping Project at that Summit reference
