KX0R was incorrectly spotted today 19 Oct 2018, on the wrong summit, but only the spot for 18 MHz CW is incorrect. The incorrect spot lists the summit as W0C/SP-102. The correct summit is W0C/FR-061.
I only activated W0C/FR-061 on 19 Oct 2018.
Earlier I posted two alerts for other summits, and then changed my mind, because of new snow falling the previous night. I found that it was not possible to delete or edit the incorrect alerts, because of work being done on the website, so I posted a new, correct alert for W0C/FR-061. The RBN Hole picked this up perfectly for three bands I used, but it chose the second incorrect alert when I went to 18 MHz.
All logs for KX0R for 19 Oct 2018 should be for W0C/FR-061.
I still had to hike in some snow, but the summit was dry, sunny, and calm, and it was a stunning Indian Summer day!
Thanks for the info George,
I see now that I logged you with the correct summit reference.
It was a joy when I managed to chase you yesterday from my rental appartment running 50 watts into my endfed wire in the balcony and the IC-706 working in remote configuration with the radio in the shack in a corner of the bedroom and myself with the control front pannel in the hall about 10m away of the shack.
It looks like conditions are getting better as I also had the pleasure to chase you twice on the 16th from my village QTH with the TH5-DX yagi and the TL-922 Amp for the 20m band chase and just my inverted vee Broadband folded dipole and about 100 watts from my TS-940S for the 17m chase.
Your signals were better on 17m than on 20m that day.
