How to Create and Upload a SOTA log using Google Sheets
I have been using Google Sheets for 4 years and it has been a very fast and efficient way to keep the log and upload it to the database. It’s simple, but there are a few tricks. Here’s how it’s done. 73
Hello Walt,
thanks for your nice video. For an alternative you should have a look at “FAST LOG ENTRY” … it’s a nice piece of software and very easy and quick sota-activator log entry possible:
http://www.df3cb.com/fle/
73 Martin, OE5REO
A great explanation of how to use a spreadsheet, which will work in the same way, whether using Google Sheets or Excel or Open Sheets.
I used to use this approach too and it works fine.
I also uploaded the same file to the chaser/S2S log - the contacts without an S2S summit indicator are rejected, but the others are uploaded from that same file. No need to search through the log and remove the non-S2S contacts as the database upload automatically does that for you.
thanks
Andrew vk1da/vk2uh
You can submit the same log as a chaser too - so you get the chaser points for the S2S
Very nice, Walt… While watching the video, I noticed you have my call wrong at 15:34 on 18/08/2015.
Elliott, K6EL
Eagle Eye EL
How could I bust such a famous callsign? 73
Thanks for the tip. I really like it. 73
You might want to try my free web tool for paper log entry.
http://sotatool.ziegler.bz/
