In the log from my last activation i made a mistake with one callsign (it is correct in my handwritten log).
How can I correct the log on the web? Must I delete the complete log of the activation and submit it again, or is there a more easy possibility?
Mike
In reply to LA5SAA:
Hi Mike,
The log must be deleted, corrected, and then re-submitted. It is easier for larger logs to be uploaded in one CSV or TSV file. An easy way to do this is by using Microsoft Excel.
Unless the database has changed recently, this is the only way to do it. I’m sure I’ll be corrected if not.
Roger MW0IDX
In reply to MW0IDX:
In reply to LA5SAA:
Hi Mike,
Or use ADI2SOTA program (V2)
http://www.sota-france.fr/telechargement-1.html
73 Alain F6ENO
In reply to F6ENO:
I am interessted in the program, but I get a virus warning on the link!
The requested object is INFECTED with the following viruses: HEUR:Trojan.Script.Iframer
73 the Hans PA3FYG
In reply to PA3FYG:
I’m looking about that
73 Alain F6ENO
In reply to LA5SAA:
That’s the way, that I do, when I made a mistake:
- Go to My activator log, Show all QSO’s, then at the bottom Save to file.
- The program save yor database to your disk.
- Open it with Excel and fix mistake. Save the file.
- Go to your activation log on Sotawatch and delete activation, where mistake was made.
- Upload fixed Excel file.
Mistake was fixed
73 de Andy - S53MN
