Help... SOTA Band choice
Hi All
I need some help… no really.
Having just built a Rock Mite and enjoyed it immensely, I am going to get myself an Elecraft K1 for QRP home use and hopefully SOTA activations. However I am torn about the version and bands to go for and use on SOTA.
I could have the 4 band version… but this does not cover 80m… and no I do not want to mess around getting the cover off and plugging in an alternative 2 band board… especially in the field.
…or I would go for a 2 band version and choose 80m and 40m.
Do you think the latter would work out given that I would then hopefully cover Europe and far flung UK on 40m and G-land on 80m?
What do you think? Do any of you use the K1? (note I have discounted the KX1 as I want to use it a lot at home too)
Thanks in advance for your opinions.
73 Marc G0AZS
In reply to G0AZS:
I used to have a K1 - excellent kit and good radio. For SOTA 40/80 would be a good choice. However note that the internal ATU option has a very limited matching range on 80m. You might also feel a bit left out if the USA or somewhere equally distant gets active - in that case you will be in a quandry about what other bands to select!
I had a 20/40 board and an 80/17 board for my K1 (that was before SOTA started).
Richard
In reply to G0AZS:
Richard
PS I have done some activations with my Rockmite - quite successfully too.
Thanks Richard…
Based on your experience, do you think the internal ATU would match a 30m top (2 x 15M) NORCAL doublet? (with a 4:1 balun)
73 Marc G0AZS
PS It’s a 20m Rock Mite so I would need more distant chasers… hi
In reply to G0AZS:
Thanks Richard…
Probably not on 80m.
Richard
Marc
I should add that there was a review of the K1 in Radcom - September 2001.
Richard
Oh dear… then maybe I’m barking up the wrong tree… I really wanted a nice self contained station and thought it would make a good choice.
…and I’m told the KX1 ATU has an even smaller matching range so maybe I need to think “external ATU” (at least for 80M)
Thanks anyway… Marc G0AZS
